Canadian Forum Canadian users, post event and club info here.
What is needed to go to a larger fuel system?
Old Nov 17, 2009 | 10:58 PM
Double_J's Avatar
This is for a FD.....
I see many people have 1600 or 1680 secondary injectors.
I know you need a different fuel rail, a fuel pressure regulator, and pigtails. What else am I missing, and what are pigtails?
Old Nov 18, 2009 | 12:47 AM
thewird's Avatar
Your missing resistors or the better route, a high impedance to low impedance (peak&hold driver) converter box (which is what I use).
Depends how much you want to spend and if you care about fuel rail looks. 1600's and 1680's are the same injector, they're just different ratings for fuel pressure.
You can get something like this which I think is the best looking one (I have this one)...
http://www.cj-motorsports.com/catrx7s1.htm (Base /w regulator, buy injectors separate 550/1600's , I have my old 550's if you go this route, only about 5k km on them before I went bigger)
Or a cheaper option is... which keeps your oem primary rail and injectors and comes with the 2 1600's...
http://www.rx7store.net/product_p/extremefuelfd.htm
Pigtails are just the connectors to splice into your harness since 1600's are top-feed and use the Bosch style connector.
However, I'd like to mention this was not related to your leaning out as the problem was fuel pressure dropping. Your injector duty cycle was still safe.
thewird
Old Nov 18, 2009 | 10:46 AM
Double_J's Avatar
thewird
You are likely right. Going to a larger setup allows for more head room if I need to upgrade to a single, more boost, plus it allows for an aftermarket FPR, and gets rid of the other solenoid you mentioned.
If the engine is coming out I might as well do it now
Old Nov 20, 2009 | 10:19 PM
DynoDragon's Avatar
Rotorite
Will the fuel pump have enough capacity to supply the bigger injectors?
Engine stand ready
Aug 14, 2015 10:26 PM
