Is there any write up for removing the MOP?????
Old Jun 11, 2002 | 04:01 PM
telus.net's Avatar
I am looking for a write up to remove the MOP so I will have no worry about bad MOP. The car runs great, but its just the MOP that just needs to be replaced. I think.
So I should just remove the MOP.
Is there any write up for removing the MOP? Preferbly with pics!
Old Jun 11, 2002 | 04:06 PM
Aaron Cake's Avatar
Engine, Not Motor
What year is your car? If it is 89+, you cannot remove the metering oil pump.
Old Jun 11, 2002 | 04:10 PM
telus.net's Avatar
Is there an MOP on 89+? I mean, I am looking at two 7s.
87 GX
- 5 lugs
- 4 pistons
- no rust
- Good price
- Power everything
90 GXL
- 5 lugs
- 4 pistons
- Good electronics
- power everything
- LSD
- Cost twice as much, but with 1 year warranty, no rust
- In new condition.
Old Jun 11, 2002 | 05:24 PM
Scott 89t2's Avatar
SOLD THE RX-7!
the 89+ is electic. if you remove the car goes into limp mode and it won't run at all.
just leave the dam thing on.... it works fine.
Old Jun 11, 2002 | 07:39 PM
Aaron Cake's Avatar
Engine, Not Motor
All RX-7s have metering oil pumps...But I agree with Scott, leave your pump on unless you have a very specific reason to remove it...If anything, replace the 4 small oil lines and clean the oil injectors if you feel like doing something.
Old Jun 11, 2002 | 07:48 PM
BlackRx7's Avatar
Daily Domestic Killer
Thought I'd butt in, but isn't it an Oil Metering Pump
:p
Old Jun 11, 2002 | 07:57 PM
my_jdm_rx7's Avatar
Yes it is OMP, oil metering pump. You are correct.
Don't F*ck with it, like someone said, from 89 on they switched to electric not manual, if you are going to start running pre-mix and that is why you are wanting to disable it, search on here for some info, there is alot. I run pre mix with the OMP still functional on my 88. Works great, keeps the engine internals and plugs nice and clean.
Old Jun 11, 2002 | 08:00 PM
Aaron Cake's Avatar
Engine, Not Motor
Technically, it's not "oil metering pump". It's "metering oil pump".
Old Jun 11, 2002 | 08:08 PM
Felix Wankel's Avatar
Super Newbie
FSM refers to it as Metering Oil Pump. I say OMP on occasion cause MOP looks funny.
Old Jun 11, 2002 | 08:13 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
lol remove the mop from your car
that does soudn funny
Old Jun 12, 2002 | 08:57 PM
RX7GT's Avatar
...must be a conspiracy
I removed the mop from mine. I also took out the broom, the dustpan and the vacuum cleaner.
Old Jun 12, 2002 | 08:59 PM
Super Newbie
My point exactly.
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
Steelwheelz
Sep 15, 2015 03:22 PM
