RX-3 brake upgrade: the final result
Old Nov 8, 2009 | 08:27 PM
Siraniko's Avatar
RX for fun
Thanks to my 12 buddies for giving the guts and ***** to put this idea in the works. So here's my upgraded RX-3 with 81-85 brake booster, clutch master, brake master and pedals. The clutch pedal just need a little tweaking-focus it away from the hump on the floor (wheel well); just a simple cut and re-weld about 1-2" inner towards the brake pedal. I didnt do this mod as I have an old school slave cylinder adjustable push-rod. With FB front brake assembly and rear-disc brake conversion, my light blue RX-3 stops on a dime with very little effort.
I took it for a drive around the block and Im very happy with the result. I just need to adjust the brake booster/pedal push-rod as the brake is not locking up but somewhat sensitive OR maybe I;m not used to it When I do the black 73 RX-3, I will use a 929 1" brake master and maybe a FC brake booster.
Old Nov 8, 2009 | 09:08 PM
islandsnow's Avatar
Wooo hooo...great job, now let's go driving
Old Nov 9, 2009 | 08:52 AM
MadChad's Avatar
Wacky, it looks like it belongs there. did you use the stock distribution block?---MadChad.
Old Nov 9, 2009 | 09:28 AM
Siraniko's Avatar
RX for fun
I used the FB...see the brake booster. I had to re-do the entire front brakes and clutch hard lines
Old Nov 9, 2009 | 12:00 PM
bosozo9's Avatar
thats sweet!! would you happen to have a picture of the modified pedals? how much cutting and banging was envolved in getting the booster in like that?
Old Nov 9, 2009 | 01:11 PM
Siraniko's Avatar
RX for fun
I will post them tonight. no bangging on the firewall or flooring. just need to re-drill a few holes and the FB assembly needs trimming
Old Nov 9, 2009 | 04:10 PM
REPUZENTN's Avatar
ROT8IN' SINCE 1991
Way to go Wacky! This makes for options and availability.
Old Nov 9, 2009 | 06:14 PM
88SE_HI's Avatar
Thats too hard core for me.
Old Nov 9, 2009 | 07:30 PM
Siraniko's Avatar
RX for fun
hardcore stuff for a hardcore rotorhead
Old Nov 9, 2009 | 07:49 PM
Siraniko's Avatar
RX for fun
For those who says **** that and I will install the FB booster without changing the pedal assembly. Well, thats not gonna work!
here is the difference between the RX-3 and FB brake/clutch pedal assemblies. The RX-3 has a 1" spacer (built-in in the pedal assembly).
this one has been trimmed along the firewall side. the stock RX-3 assembly has a bracket on top where the steering column is bolted to.
so the first thing you do is to get a 1/4 aluminum plate or whatever you prefer and use the FB pedal assembly as a template plus something to keep the moisture from coming inside the compartment (I used a paper gasket). the white plate is the panel that I cut out from a junk FB as my initial template or when I came up with this idea.
Then remove the gauge cluster (tach/speedo), unbolt the RX-3 brake booster/clutch master and steering column from the "stock RX-3 pedal assembly."
Note that the RX-3s booster has 3 studs (instead of 4 like the FB, RX-4 and RX-2). using the 2 passenger side brake booster holes in the firewall, install the aluminum template from the inner firewall (inside). Then mark the 2 extra holes for the booster and 3 holes for the clutch master (2 small and 1 large). then drill away. For the clutch master, drill several small holes to cut out the large hole and finalize it with a die grinder. Also, you will need to grind a small partition to the right of the clutch master (engine bay) and paint it to prevent rust. The result will look like this
Install the FB brake booster first, then the FB pedal assembly and finally the clutch master. you will also need to make new hard lines for the front brakes and clutch master. then the last thing: fabricate bracket to secure the FB brake assembly to the dash and to secure the steering column.
I did all these in 1 day as I worked alone with the company of my 12 buddies. I noticed a big difference over my RX-3 brakes with RX-4 booster.
Old Nov 9, 2009 | 07:59 PM
Siraniko's Avatar
RX for fun
I forget to mentioned that I used the stock RX-3's clutch pedal push rod as it is longer than the FB. This is ideal for those who are running a very stiff pressure plate (3,000lbs and up).
also, I tried to use a 929 brake booster on a FB pedal assembly. that didnt work as the 929 is larger than a FB and will not clear the clutch master. When I have time, I will try the FC brake pedal assembly but for sure, my other RX-3 will have the 929 1" brake master.
I know that this will work on a RX-4 but I need a someone with a RX-2 as a volunteer
Old Nov 9, 2009 | 08:15 PM
Trini 16's Avatar
Rotor junkie
great job, now come to ny and do my rx4 lol
Old Nov 10, 2009 | 08:07 AM
Siraniko's Avatar
RX for fun
I installed them in this sequence:
booster/clutch master ==>> aluminum plate ==>> gasket ==>> firewall ==>>pedal assembly
The aluminum plate and gasket are optional. I installed them to provide extra support to the firewall due to the extra holes and the gasket is to keep the moisture out as noted earlier.
Old Nov 10, 2009 | 12:36 PM
bosozo9's Avatar
do you have a picture of how you tweaked the clutch pedal? the best i was able to do was adapt a 15/16" MC(infinity j30) on to the stock booster.
Old Nov 10, 2009 | 12:59 PM
Siraniko's Avatar
RX for fun
not sure if the flange from infinity is the same as the mazdas
Old Nov 10, 2009 | 11:47 PM
SAVANT's Avatar
I SMELL GAS
I love it and remember Wacky im next in line........muah hahahaha i need this done bad my car is scary as hell with these stock brakes =(
Old Nov 11, 2009 | 04:40 PM
Siraniko's Avatar
RX for fun
I went out for a joy ride at 4AM today. Im happy with the result, brakes are as good as my other FBs and prior FCs. Just get all the parts and I will do the complete swap for you, although it may take a couple of days since you need a complete front and rear brake upgrade also. I got to check out the junkyard also this weekend and see if I can use the B-series mazda pick up trucks pedal since they have a better off-set. new idea came out after a did a clutch job in my buddy's truck today.
Old Nov 11, 2009 | 08:18 PM
Smeagol's Avatar
We can do this with one of my RX-2's, heh. My sedan with the S4 13B would be a perfect candidate since it's got a bad booster currently. I've been meaning to upgrade the brake master cylinder on a couple of them but this sounds like a better idea. I only have rear disc on one of the 2's though, need to get moving on the others.
Mike
Old Nov 11, 2009 | 09:14 PM
Siraniko's Avatar
RX for fun
bring it down to LA homie!
Old Nov 14, 2009 | 12:20 PM
Siraniko's Avatar
RX for fun
removing thick aluminum plate. its over kill. switching to a thinner plate (aluminum or sheet metal)
Old Nov 15, 2009 | 05:12 AM
sen2two's Avatar
Rx2 > FD
if you upgrade to the 929 master cylinder, you might be able to just drop the booster all together. Its perfectly safe to delete the booster and clean up the engine bay. I just wouldnt do it on the stock rx3 master cylinder.
you just have to shorten the shaft that goes into the master and mount it. wich might be a lot easier than everything else...
Old Nov 15, 2009 | 10:16 AM
Siraniko's Avatar
RX for fun
thats for my other RX-3. 929 master but on a FC booster. I prefer to keep a booster.
Old Nov 16, 2009 | 02:33 PM
13BT_RX3's Avatar
The General RE
Will the 929 master fit on the RX3 booster?
Old Nov 16, 2009 | 03:21 PM
Siraniko's Avatar
RX for fun
I will let ya know within the next few weeks.
Old Nov 17, 2009 | 03:00 AM
bosozo9's Avatar
the 929 master will not work with the rx3 booster i tried it will not even come close to working
