Old 10-06-09, 11:51 PM   #1
coxxoc
Shooting for 500
coxxoc's Avatar
How to: Pinion snubber install
Rationale:
I got tired of the clunking coming from the rear end of my car. Last year I replaced the front differential mount with the Mazda Comp version. My mount wasn't broken and it didn't help. What I saw was that since my car was lowered a lot, my rear suspension would hit the underbody at times. I think this is due the aftermarket one piece rear-link (camber link) design used to correct rear camber I have installed. It brings the sub-frame and front of the differential closer to the body. A pinion snubber is cheap at less than $10 dollars, and the job is pretty easy to do. There wasn't a good write up on the forum so here you go. The pictures are gathered from other posts and from the service manual.
Tools needed:
Hydraulic jack
Jack stands
17mm wrench
Various sockets 10mm, 17mm, 20mm (maybe it was 21mm?)
Ratchet
Torque wrench
Phillips head screwdriver
Drill and bits up to 3/8"
Parts needed:
Pinion snubber (came with locknut) http://www.summitracing.com/parts/ENS-9-9101G/
3/8" x 2" fender washers
Installation:
1. Remove the rear bins.
2. Drill a 3/8" hole in the dimpled area on the tunnel. The dimple is underneath the sound deadening mat in between the recessed bin areas.
3. Jack up the car enough to comfortably work under the diff area. Be safe and use jack stands. You'll need to use the jack to assist in adjusting snubber preload later; so you can't skip this.
4. Loosen the front mounts on the rear subframe. Only loosen the large nuts attaching the subframe to the mount bracket. Do not loosen mount bracket from the body. These mounts are on either side of the body just in front of the rear wheel well.
5. Remove the lower bolt from the rear link.
6. Install the pinion snubber in the hole you drilled earlier. It should be visible above the front differential mount area right in between the parking brake cables. Pull down on the front of the differential housing to create clearance to install the snubber.
7. Reinstall the bottom bolt in the sub-link.
8. Jack up the subframe to its normal position.
9. Check to make sure that your snubber is slightly preloaded. If there is a gap, lower the subframe, the revert back to step 5. Add fender washers in between the snubber and bottom of the body to space it out. I added two fender 3/8" x 2" fender washers to mine to get the preload just where I wanted.
10. Tighten up the pinion snubber. I used another fender washer up top as well to tighten on a flat surface.
11. Tighten the subframe nuts to 74-87 ft/lbs.
12. Tighten the sub-link nut to 54-69 ft/lbs.
13. Install the rear bins.
14. Lower the car off of the jacks.
14. Go test drive and enjoy your non-wheel hopping, non-clunking rear end!
Josh
ID:	362724   Click image for larger version
ID:	362725   Click image for larger version
13BRE, Streetport, Wolf3D V4, Garrett T04R .70/1.00, HKS 50MM wastegate, 850/1600, Coolingmist AI
coxxoc is offline   Reply With Quote
Old 10-07-09, 12:49 AM   #2
KhanArtisT
Liberators!
KhanArtisT's Avatar
Send a message via AIM to KhanArtisT
Can you explain why the subframe has to be lowered? On my install I just jacked the car up and installed the snubber b/w the diff and chassis and adjusted preload as necessary.
Also remember that most advance and autozone stores should carry the pinion snubber! Its made by energy suspension and its called a bump stop or something.
KhanArtisT is offline   Reply With Quote
Old 10-07-09, 01:36 AM   #3
dkwasherexd
Blown Apex Seal !
dkwasherexd's Avatar
Send a message via AIM to dkwasherexd Send a message via MSN to dkwasherexd
great writeup! I have gone through like 3 diff mounts and 2 rear subframes. If I dont break a diff mount, the subframes diff mount will break instead -_- Getting sick of going under and replacing the subframe and diff over and over... I shall do this mod haha
Guys night out!!1111
dkwasherexd is offline   Reply With Quote
Old 10-07-09, 07:22 AM   #4
coxxoc
Shooting for 500
coxxoc's Avatar
I had to loosen the subframe for clearance. I couldn't fit my hands up there without loosening and pulling subframe and front of the differential down some.
Old 10-07-09, 07:59 AM   #5
arghx
fast car=no money
arghx's Avatar
Good writeup. Maybe I should do this to my car, I still have stock diff mount and I'm worried about breaking something. So can this install be done without loosening the subframe bolts then, depending on how much the car has been lowered? Also, did you remove your exhaust for this?
-- 1988 Rx-7 Turbo II, T04R
-- 1997 Infiniti Q45 Touring
-- Sold: 1988 Rx-7 GTU, 172rwhp all motor
-- RIP: 1989 Supra
arghx is offline   Reply With Quote
Old 10-07-09, 12:26 PM   #6
MaczPayne
Dirty Harry
MaczPayne's Avatar
Send a message via AIM to MaczPayne
Finally, a write up! This mod is very common among v8 FC owners, and it works!
Pinion snubber + MMR diff bushings + comp. front mount = Bulletproof
My sub-link camber adjuster is practically useless now since the diff is so firmly mounted and "snubbed".
It's possible to install this with your exhaust on, but the job is just so much simpler with it out of the way.
Johnson
RIP 1/16/10
89 Jeep Comanche - Goes where the 7 can't
MaczPayne is offline   Reply With Quote
Old 10-07-09, 03:32 PM   #7
coxxoc
Shooting for 500
coxxoc's Avatar
I did it with the exhaust on. My car is very low and probably directly attributed to my need to lower the subframe. Only part of the sidewall is visible on my rear tires. You can't really tell how low it is because I have a stock body.
Old 10-07-09, 07:35 PM   #8
Hypertek
Me against the club
Hypertek's Avatar
i did mine without touching the subframe. What helps is using a dremel to make a "slot" in the stub for the bumpstop so when you have it in the hole, from the inside, you can use a flathead screwdriver to keep the stud from spinning while you tighten the bolt.
Hypertek is offline   Reply With Quote
Old 10-07-09, 08:06 PM   #9
arghx
fast car=no money
arghx's Avatar
Could you elaborate a little further? Maybe post a crude MS Paint diagram or something?
-- RIP: 1989 Supra
Old 10-07-09, 08:15 PM   #10
ifryrice
Sequentially broken
ifryrice's Avatar
I believe he's saying to dremel a channel in the threaded stud coming out of the snubber. When you have it in the hole you drilled while tightening you can use a flat-head in the channel to keep it from rotating while tightening the nut.
ifryrice is offline   Reply With Quote
Old 10-26-09, 02:04 AM   #11
hiroichi1515
Rotorite
Since the pinion snubber goes over the little block on the front diff mount, it should be possible for me to install that with a broken diff mount (Rubber separated from mount) or do I have to replace the diff mount before I put that on?
hiroichi1515 is offline   Reply With Quote
Old 10-26-09, 02:23 AM   #12
SmogSUX
No money. No love.
SmogSUX's Avatar
Trader Score: (6)
Send a message via AIM to SmogSUX Send a message via MSN to SmogSUX
I had Rotary Evolution install mine..WORLD of difference. Sliding, drag racing, and even just cornering. Pretty much got rid of ALL my wheel hop. Best mod EVAR
1988 Mazda RX-7 Turbo II Anniversary Edition- HOLSET HX40 POWA!
1989 FUGLY 240SX -dohc swap in progress
1998 Volvo T5 - NEW DD
SmogSUX is online now   Reply With Quote
Old 10-26-09, 03:22 AM   #13
VividMP5
VividMP5's Avatar
Trader Score: (24)
Nice! This is going to be on the list of things to do!
VividMP5 is offline   Reply With Quote
Old 10-26-09, 01:12 PM   #14
MaczPayne
Dirty Harry
MaczPayne's Avatar
If your rear diff bushings are worn out, be sure to replace those too.
Johnson
RIP 1/16/10
Old 10-26-09, 02:24 PM   #15
KhanArtisT
Liberators!
KhanArtisT's Avatar
Yup, thats part of the reason why this mod is so popular. I'm running mine with a broken front diff mount (but new rear mounts) and it feels waaay better. Not perfect though, you still hear a light thud when shifting but way better than a clunk.
Old 10-26-09, 03:16 PM   #16
fc3schick87
girls can too
fc3schick87's Avatar
Send a message via AIM to fc3schick87
good post. i use this , but remember if your driving hard u may bend the metal under the bins like i did
s4 tii swap
Rtek engine management system, t3/t4 turbonetic hybrid turbo (high flow),revII racing beat exhaust
"Girls can too - And Often do it better" Is far, far more accurate!
fc3schick87 is offline   Reply With Quote
Old 10-27-09, 03:28 PM   #17
lonewolfrx
lonewolfrx's Avatar
Send a message via AIM to lonewolfrx
nice post.. im planning on doing this when i have free time
87 fc - full s4 n/a bridgeport. headers, racing beat dual exhaust, test pipe, still on stock ecu and afm, rear diffuser. (temporarly swapped s5 motor to build up the bridge)
90 suzuki gsx 600f katana
91 toyota mr2 - work in progress
90 acrua legend - sold -
lonewolfrx is offline   Reply With Quote
Old 10-27-09, 04:42 PM   #18
staticguitar313
R.I.P. Icemark
staticguitar313's Avatar
Send a message via AIM to staticguitar313
good post, did this myself about 2 years ago when i still had my FC, saved me quite a bit of agony
1993 VR Touring FD AZRR SP rebuild.
staticguitar313 is offline   Reply With Quote
Old 11-09-09, 01:42 AM   #19
nightridaz777
Welded Ass Hell
nightridaz777's Avatar
Send a message via AIM to nightridaz777
yeah just did this mod myself. feels wayy better. took away all wheel hop.
1987 GXL (Drift Machine!)
1989 GTU (Daily Driver)
1986 Base Model (Stripped And Junked)
nightridaz777 is offline   Reply With Quote
Old 11-09-09, 09:12 AM   #20
arghx
fast car=no money
arghx's Avatar
I'm having trouble motivating myself to get started on this. I just did a bunch of work to my interior and I don't want to pull those storage bins out and risk braking more plastic.
-- RIP: 1989 Supra
Old 11-09-09, 10:36 AM   #21
solareon
removing the storage bins won't break any plastic. it's all screws and no snap fit crap
87 T2 - Streetport, BNR Stage 2, RB Rev TII, Rtek 2.1, 720/1000 Injectors - 323hp/294tq
90 GXL - Streetported. RB headers, presilencer, and cat back. Rtek 2.0 and HKS air filter. - Even slower
solareon is online now   Reply With Quote
Old 11-09-09, 08:27 PM   #22
tigerbite
PSN ID = AsianSausage
tigerbite's Avatar
I am going to do this mod soon. What is the estimated time to do this mod? Maybe 3 hours?
tigerbite is offline   Reply With Quote
Old 11-09-09, 10:58 PM   #23
ForsakenRX7
zoom zoom go boom
ForsakenRX7's Avatar
Send a message via AIM to ForsakenRX7
If that. With everything laid out it should be a quick job. This is a necessary mod though.
86 n/a base rx7-under the knife
ForsakenRX7 is offline   Reply With Quote
Old 11-09-09, 11:23 PM   #24
turboIIrotary
is this the same on a vert?
turboIIrotary is offline   Reply With Quote
Old 11-10-09, 01:21 AM   #25
nightridaz777
Welded Ass Hell
took me less than a hour to do the mod.(most of the time it was finding the right size spacer)
aim9, bump, drag, energy, fc3s, installation, installed, photo, pictures, pinion, racing, snub, snubber, stop, suspension
HTML code is On
