temp gauge is bouncing
Old Sep 30, 2009 | 04:59 PM
450riden's Avatar
I got in my car last night and turned on the lights. when i did the dash lights were out then they came back on. after this happened it was warming up and the temp gauge dropped off suddenly then started bouncing with the rpms. i got in it today and the gauge started going up then dropped off again. i dont want to run it without knowing if im cookin it. maybe a bad ground?
Old Oct 2, 2009 | 10:06 AM
Aaron Cake's Avatar
Engine, Not Motor
Bad battery cables or ground, or a failing alternator.
Old Oct 3, 2009 | 04:21 PM
450riden's Avatar
I found a broken wire. Someone hacked one in that came loose. All good now.
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
vmerino
Sep 5, 2015 11:26 AM
