Technical Question!!
Ok i have a 1990 turbo 2 fc. The other day i checked the spark plugs and saw that one spark plug was oily. How would i fix that?
Does an NA 1986 fc transmission fit my car? It seems i grind the transmission twice due to the clutch or could it be the clutch? My car is running out of clutch and the other day i shift it too slow and kind of grind.
First check your intake plenum see if it has oil in it, then it will be your turbo seal leaking. If not it's the rotor oil control rings are worn out and you will need to rebuild it. FYI! it's a rotary there are no valve seal on the engine.
Donald Hampton
16
Nov 23, 2022 06:38 PM
Adaptronic S5 Turbo PNP Unit questions
_Tones_
May 25, 2021 05:37 AM
rx8volks
Canadian Forum
Sep 1, 2015 11:02 PM
