clutch stop piece broken
Old Sep 13, 2009 | 05:02 PM
Premiumriceonly's Avatar
i recently heard a clicking in my clutch when released all the way. i found pieces of a blue glasslike substance on the floor and when i checked out the clutch i saw theres a white plastic piece that goes through a hole in the clutch when released fully
i aslo saw the blue glass stuff around this piece. the clicking i heard is this piece hitting the edge of the hole on the clutch and then sliding in
anyone had this problem or know how to fix?
Old Sep 13, 2009 | 05:12 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Need pictures
Old Sep 13, 2009 | 07:06 PM
k workin on getting a picture. the white piece looks like a sensor for the clutch because its hooked to something electrical
im guessing it could be for the cruise control maybe
like i said tho pic comin soon
Old Sep 13, 2009 | 07:54 PM
Rx7_Nut13B's Avatar
I know what it is, the blue glass thing is a stop that is suppose to go into the hole that the white switch (Cruise Control Disengage) is going into.
When that part gets old it will finally break down and fall out of the hole, all you really need is something to plug that hole up so that the switch is pushed in when the clutch pedal is disengaged.
Old Sep 13, 2009 | 10:26 PM
haha there you go.
sounds like a 1 dollar do it center fix haha
thanks for the help
Old Sep 13, 2009 | 11:15 PM
RotaryRocket88's Avatar
Top Down, Boost Up
I had the little plastic stop break on mine too. A short bolt and nut through the hole will work as a replacement.
Old Sep 14, 2009 | 01:11 AM
nice thats a good idea
i was gonna see if i could work something up with a rubber stop since that seems what was there before
either way is fine
Th0m4s
Feb 26, 2019 02:04 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
