Go Back   RX7Club.com > Tech and Performance > Single Turbo RX-7's
Old 09-09-09, 03:50 PM   #1
black06g85
that random guy
black06g85's Avatar
single turbo 93 oil issues
Having an issue with the car blowing oil out the turbo under full boost above 5600 rpm, cruising it's fine and boost on the dyno was only at 8-9psi (also wouldn't hold boost, but that's another part).
every attempted pull the car would smoke out the shop quite bad, drove it 100 miles home, wot'd on it a few times and it hasn't smoked again.
it's a 93 aggressive street ported motor, 550/1600 walbro 255, fmic, gt3582r modified rx7 store mani (I think) 3" v-band outlet to d.p. to 3.5" greddy cat back. Apex power FC w/dataloggit.
Turbo is 2 weeks old, never seen full throttle until yesterday, wasn't smoking again last night.
2006 cobalt ss/sc turbo swap 500+whp (until motor blew lol)
9500 rpm pull (2nd one)
93 RX-7 383WHP 12psi pump gas
black06g85 is offline   Reply With Quote
Old 09-09-09, 04:42 PM   #2
black06g85
that random guy
black06g85's Avatar
Old 09-09-09, 04:56 PM   #3
1Revvin7
The answer is simple
1Revvin7's Avatar
Trader Score: (7)
Send a message via AIM to 1Revvin7
What size oil feed line, and restrictor? What size return line? How is your crankcase vented?
1Revvin7 is offline   Reply With Quote
Old 09-09-09, 06:12 PM   #4
arghx
fast car=no money
arghx's Avatar
I bet he capped off the oil filler crankcase ventilation
-- 1988 Rx-7 Turbo II, T04R
-- 1997 Infiniti Q45 Touring
-- Sold: 1988 Rx-7 GTU, 172rwhp all motor
-- RIP: 1989 Supra
arghx is online now   Reply With Quote
Old 09-10-09, 07:04 AM   #5
black06g85
that random guy
black06g85's Avatar
ok found some issues, the check valve from the oil fill cap to the mani was clogged, and the 2nd port was capped off by the previous owner for some reason. Redoing the PCV system and new catch can tonight. Also one of the t-bolts on the FMIC had broken on the dyno I guess, probably why it wouldn't hold boost for shit.
oil feed is a -4an line adapted off the stock feed, I did run the restrictor in the feed, return is a -10an (2 45deg's so it's pretty much straight down). to the front return flange.
Pretty sure it's just a PCV issue, will know more tomorrow night when I put it back together.
Old 09-14-09, 12:44 PM   #6
black06g85
that random guy
black06g85's Avatar
well redid some things this weekend, will post up the pics tonight. Added a new 3/8 vent line and catchcan. Cleaned the old check valve out and it now actually works. Fixed the boost leak. now the car is lean as hell so I can't really drive it until I bring back down to finish tuning it.
unless someone has a decent fuel map I can use until then (street ported, gt3582r 550/1600's)
Old 09-15-09, 11:39 PM   #7
catch-22
naw....there bonus parts.
catch-22's Avatar
you dont need the PCV valve to the intake, just vent the crankcase.
catch-22 is offline   Reply With Quote
Old 09-16-09, 06:34 AM   #8
black06g85
that random guy
black06g85's Avatar
well I did both. can't hurt hopefully.
trying to get in touch with the shop to get my car back in to finish tuning it. Can't tell if it's fixed until then.
Old 09-18-09, 01:49 PM   #9
black06g85
that random guy
black06g85's Avatar
well richened it up a little last night and took it for a few 7500 rpm blasts around the neighborhood. no more smoking yay.
Old 12-02-09, 07:22 PM   #10
mannykiller
The Professional
mannykiller's Avatar
Trader Score: (6)
Post Pics man!! I think my pcv valve is clogged as well...
mannykiller is offline   Reply With Quote
Old 12-02-09, 07:54 PM   #11
black06g85
that random guy
black06g85's Avatar
I dunno how well you can see what we did, but it works
Old 12-02-09, 07:54 PM   #12
black06g85
that random guy
black06g85's Avatar
93, line, oil, rx7, rx7club, single, swap, turbo
