Haltech DOSBOX issues?
Old Sep 8, 2009 | 07:45 PM
ziig's Avatar
OH DOSBOX issues?
got it running but still have some problems......lets recap a bit first!!
So finally after a month of fiddling around I realized I had my DosBox configured wrong...I dint have my Haldos file saved in my C drive...I had it in my documents..lol
so when I opened the dosbox i could run haltech but not get to files...well it took me a month but i figured it out today!!!!
however, i did notice my TPS would work fine, then all of a sudden it would stick, and rpm values would get reveresed..so 10500 rpm at closed and zero WOT...si i tried to calibrate TPS but it says no movement of TPS..
If i close DosBox and reopen it works fine again...but it did this about 3 times....
on a side not anyone ever have plugs go out totally dead in a day of just starting and idleing?
any input on both of these will be great...ohhh yea I can finally get to upload Brian Cains MAP, but i need a 3 bar to run it....
I have a 2 bar does anyone have a 2 bar map for a BP with high comp rotors..720 prim. and 1680 sec. ?
Cheers
henry
Old Sep 9, 2009 | 09:33 AM
xxtremes33's Avatar
my dosbox will randomly stop reading ANYTHING sometimes. i have to restart it and it works fine again. and yes i have fouled out plugs in a single day. especially when i first started the car with the haltech and it was running ridiculously rich. i probably went through 3 sets o f plugs within the first week trying to get the fuel maps dialed in better. hope that helps
Old Sep 9, 2009 | 06:45 PM
ziig's Avatar
thanks it helps alot...i figured it was just a flodding issue , but i never had plugs go so easily before...
I have another question too...I have a 2 bar map sensor but my e6k map is for a 3 bar...i try to start car on the 2 bar base map and it misses and sounds like it is runnig on one rotor..
I tried to use the 3 bar map today and the car actually started easier and ran a bit cleaner..still a little miss...anyone know if i can run a 2 bar on a 3 bar map without BOOST of course and be ok?
rgordon1979
40
Mar 15, 2022 12:04 PM
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
betes
Sep 27, 2015 08:25 AM
Steven_McKinley
Sep 5, 2015 10:48 AM
