Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
Converting 13b rew to na help
Old Sep 3, 2009 | 08:33 PM
widebodyseven's Avatar
Formerly widebodyseven
I want to convert my 13b rew to na and need some help.
I know i need to block off the oil and coolant lines to my turbo and cap off all my vacuum lines.
Im running a power fc untuned, would i need to do anything about the ecu?
To me converting it to na sounds simple but is there anything else im missing?
Thanks
Old Sep 5, 2009 | 10:59 PM
Tom93R1's Avatar
gross polluter
Don't really need to do anything with the ECU, but you might as well retune. You could get more resolution in the vacuum to atmospheric pressure ranges. Might not change a lot but since your exhaust back pressure will be different as well as the intake...
Old Sep 9, 2009 | 12:29 PM
rotarygod's Avatar
Rotors still spinning
You'll need a header and a little bit of exhaust work. It's basically just removing the turbos and intercooler, using an n/a style exhaust, and running a filter on the throttlebody. Preferably somewhere where it will get cool air. Plug the oil and water lines to the turbo and retune the ecu. That should basically be it. Keep in mind that you do have lower compression than standard n/a rotaries.
Old Sep 9, 2009 | 12:39 PM
I just bought the RB header and modified from 2 pipes to 1.
Already got the air filter on arround the headlight area.
Plugged all the oil, water and vacuum already too.
I also did some extra stuff like rerouting more air to the intake from bumper and covering my radiator so the engine doesn't get heat soaked.
I'll post some pics soon
Old Sep 9, 2009 | 12:57 PM
rotarygod's Avatar
I'm curious why you are going this route? Not questioning the logic behind it. I'm just curious. FWIW: If I ever own an FD, it will be n/a and Renesis powered so no turbo for me either. I've been there and done that.
Old Sep 9, 2009 | 02:56 PM
diabolical1's Avatar
+2 on the note of curiosity.
unlike both of you, my would-be FD aspirations would most definitely include a turbo, but that's for another thread, i'm sure.
Old Sep 9, 2009 | 02:58 PM
rotarygod's Avatar
If my FD aspirations ever did get into the forced induction world, it would probably involve something on top of the motor with a couple of large inward spinning screws.
Old Sep 9, 2009 | 10:32 PM
The reason im going na for now is bc my turbo is leaking oil like crazy (single turbo) and i call 3 shops arround my area to get it rebuilt but no one can do it bc they don't have the parts for it. I've also been working on this car for 3 years now and want to take a break and save alot of money to get a 3 rotor later.
Im also doing this so i could make it to sevenstock.
Old Sep 10, 2009 | 12:48 AM
I ran into a little problem, my car ran find with no headers but after i put the headers on it starts and dies but i don't think thats the problem i think it has something to do with the vacuum lines.
What am i supose to do with the fuel injector atomization?
Also do i need the presure sensor still?
Those were the only thing i messed with after it was running fine.
Here are some pics.
Old Sep 10, 2009 | 12:59 AM
jaggermouth's Avatar
Will TIG for 20b
You will still need the MAP sensor.
My REW currently still has the twins on, but they are just bolted on, no piping or anything. It's been running fine, but killer rich.
Is it possible you have a large vac leak?
Also, thanks for the wicked rad ducting idea
Old Sep 10, 2009 | 01:43 AM
Where am i supose to connect the fuel injector atmoization line?
I think thats my only problem right now.
Also the rad ducting is probably my favorite part of this conv. it looks cool and should work fine with my vented hood.
Old Sep 10, 2009 | 03:53 PM
Tom93R1's Avatar
gross polluter
What's a "fuel injector atomization line"? post a pic of it.
Old Sep 10, 2009 | 07:47 PM
Theres a picture on post #20 it says you have to conect it to a intercooler pipe but i don't have one.
https://www.rx7club.com/showthread.p...vacuum+diagram
Old Sep 10, 2009 | 11:34 PM
Tom93R1's Avatar
gross polluter
I would probably just put a cap on the nipple for that one.
Old Sep 10, 2009 | 11:43 PM
Thanks
Im going to try and finish this car up tomorrow hopefully there won't be any more problem.
Old Sep 11, 2009 | 12:02 AM
20BENZ's Avatar
It's all in the timing.
hehe, + 1
Old Mar 18, 2011 | 12:49 AM
rescueranger's Avatar
^bump
any update on the project?
did you have to tune the ecu?
Old Mar 18, 2011 | 01:35 AM
Originally Posted by rescueranger
^bump
Wow surprise to see this bump.
Unfortunately i sold the car a couple months after i finish this project.
But here's a video some one took of me leaving sevenstock a few years ago. 13B REW open headers.
www.facebook.com/v/141244013388
Old Mar 18, 2011 | 06:29 PM
t-von's Avatar
Rotor Head Extreme
NA Renesis Fd? I know power to weight wise it's an improvement over the Rx8 but why not go NA 20b instead for the improved torque?
Old Mar 18, 2011 | 08:13 PM
did you have to re-tune the ecu? or was it just straight bolt/unplug job?
Old Mar 18, 2011 | 08:52 PM
arghx's Avatar
rotorhead
you act like you can just pick up a 20B in a junk yard...
Old Mar 18, 2011 | 09:08 PM
nope same tune as the twins with bolt on. Drive and idle fine but i've only driven it for like 10 min.
Old Mar 18, 2011 | 11:33 PM
t-von's Avatar
Rotor Head Extreme
20b's are just as available as Renesis engines. Either way you would still have to fit the Renesis in the the Fd chassis and do a lot of custom fab work to make either engine run. 20b's have the advantage of having subframes available. Not so with the Renesis. The only main difference is you spend more money for the 20b engine and custom headers. Everything else is a wash!
Lou Byer
20
Oct 12, 2020 08:03 PM
Ian_D
Oct 14, 2015 12:31 PM
Ian_D
Sep 6, 2015 10:38 PM
