Canadian Forum Canadian users, post event and club info here.
Mazdees – Dragonwerks Open House / Dyno Day / BBQ
Old Sep 2, 2009 | 12:58 PM
DynoDragon's Avatar
Rotorite
Toronto / GTA
Dave and Jo are holding an Open House to say thanks to all their customers and to introduce their services to the miataturbo.net club members.
Date: Sat, Sept 26, ’09.
Drop in from 11:00 am ‘til 3:00 pm.
Barbeque from 12:00 pm to 2:00 pm.
Dyno runs: 2 for $70 from 9:00 am until 5:00 pm. (appointments preferred)
(It would be great, if you could let us know if you’re planning on coming) jo.demarco@dragonwerks.ca or Mazdees@rogers.com
Mazdees has been specializing in Mazda cars for 25+ years. They are a one-stop shop for all your mechanical needs from regular maintenance to extreme modifications.
| Rotary engine specialist | Custom SS exhaust | Suspension | Complete Turbo and Supercharger system installation |
Mazdees
Dragonwerks offers chassis dyno testing and tuning on their Mustang dyno. Check out the website for more details.
Dragonwerks
Old Sep 3, 2009 | 12:08 PM
brian92jdmfd's Avatar
ya Ill call or send E-mail in a few days, Im coming
Old Sep 4, 2009 | 09:49 AM
IAN's Avatar
IAN
Rotary Reborn!
Jo,
I should be able to go. First I need to check my ignition hesitation. May just need new plugs and I am waiting on the race plugs.
Should I aim for 25psi
Ian
Old Sep 4, 2009 | 10:39 AM
thewird's Avatar
I might come
thewird
Old Sep 4, 2009 | 11:51 AM
Double_J's Avatar
I might come if my HKS ignition comes in. It would have to be in the morning as that's my moms BDAY.
Old Sep 5, 2009 | 11:10 AM
pd_day's Avatar
Spoolin'
I might swing by.
Is this a 2WD or 4WD dyno?
Old Sep 6, 2009 | 11:05 PM
DynoDragon's Avatar
Rotorite
Originally Posted by pd_day
I might swing by.
2WD Mustang Dyno: dual roller, power-absorbing type, 900HP max
-Jo
Old Sep 13, 2009 | 05:43 PM
binz's Avatar
they spinnin'
i will try to make it...
Old Sep 25, 2009 | 07:24 AM
IAN's Avatar
IAN
Rotary Reborn!
Bump for tomorrow
Old Sep 25, 2009 | 09:33 PM
Double_J's Avatar
I will be there. I want to see what my untuned car will pull.
Old Sep 25, 2009 | 10:03 PM
JDK's Avatar
JDK
Not a wise ideal
Old Sep 26, 2009 | 12:51 AM
Zhι's Avatar
raawwwwrf
i might be going on the dyno tomorrow as well, except i just got a tune from our local super tuner Marco Jorge.
three for our own Steve Kan!
Old Sep 26, 2009 | 12:54 AM
thewird's Avatar
^ lol
thewird
Old Sep 26, 2009 | 04:03 PM
Double_J's Avatar
Originally Posted by jim kutschke
Not a wise ideal
Darrly checked my afr for me, and he said it was safe.
I was hoping to get 250HP but I ended up putting down just under 290HP. They said it was 302HP when corrected to the temperature. It boosted a bit higher than I would have liked, 15lbs.
I have already bought a boost controller, BNR stage 3, larger injectors, alluminum flywheel, 3 bar map sensor, and clutch. Is it reasonable to expect 375-400HP once these upgrades are installed?
The thing I found odd was my meth kit had no impact on my afr. I am running 50/50.
I ran out of meth at mosport so it certainly was pumping then. Guess I will have to check it again.....
Old Sep 26, 2009 | 07:00 PM
IAN's Avatar
IAN
Rotary Reborn!
There was only one car over the 400rwhp mark. About 430. Old procharger camaro. Very nice car.
Only one rotary car was on the dyno. double_J I believe.
Can't wait to test out my autronic ignition amp and turn up the boost to whatever the turbo will put out
Old Sep 26, 2009 | 08:39 PM
v6er's Avatar
Was there today but didn't get a chance to hangout for long. Thewird, saw your fd inside the shop i think and had written 77 on it if i am correct? There was another MB fd beside mine. Let's see if i can make it to the meet in October sometime once i have evrything sorted out.
Old Sep 26, 2009 | 09:13 PM
IAN's Avatar
IAN
Rotary Reborn!
O and I forgot to say thanks Dave for the burgers and to Joe hosting another dyno event.
Old Sep 26, 2009 | 10:09 PM
thewird's Avatar
Not on a Mustang dyno. You'll be in the 330-360 rwhp range assuming you tune to 18-20 PSi.
It's too bad Zhe chickened out for the dyno. I was curious to see what it was putting out :P
thewird
Old Sep 26, 2009 | 11:29 PM
Zhι's Avatar
raawwwwrf
meh
Old Sep 27, 2009 | 02:39 PM
Double_J's Avatar
thewird
40 more HP is good but not great. I guess the 400HP range is on a dynojet?
Old Sep 27, 2009 | 02:53 PM
thewird's Avatar
Or a dynopack. It's just a number. Is the number going to affect how you feel about the power?
thewird
Old Sep 27, 2009 | 04:16 PM
Double_J's Avatar
thewird
Nope but it's nice to hit a specific number. You said you wanted 500, I want 400. Your right at the end of the day its just a number.
Old Sep 27, 2009 | 04:35 PM
thewird's Avatar
Well, I want 500 on Joe's Mustang dyno at 25-30 PSi running 100% methanol and have a decently sized single turbo to do it :P. Probably make more elsewhere. It's just an invisible target really, I'm pretty sure I can hit it and that is why I am aiming for it but realistically it will probably be higher.
On another note, I think you'll have a hard time hitting 400 on your setup even on another dyno.
thewird
Old Sep 27, 2009 | 04:54 PM
Double_J's Avatar
What were you able to squeeze out of your BNR's? I thought the norm was in the high 300's.
Old Sep 27, 2009 | 05:05 PM
thewird's Avatar
330 rwhp @ 16 PSi on pump gas with ported intakes and FEED big throttle body and a fairly big street port on the Mustang. This was without weather correction. However, my tuning was fairly conservative at that point but it didn't have much more in it. This was also with 3mm one piece ceramic seals so there may be some power missing from going with the one piece design.
thewird
