cobra wheels on my fc???
Old Aug 21, 2009 | 02:18 PM
Peteypop426's Avatar
ZOOM ZOOM
FL cobra wheels on my fc???
ok im looking for a set of wheel i can put on when i go to the local track and i found these.
03 stock cobra rims.
tire size on 2 is 275 40 r17 hankook radial
and the other 2 is M/T drag radials 275 40 r 17
my question is will this work? or will i need spacers? n how much is that?
i kno the bolt pattern is the same as mines. 5x114.3
i dont kno much about wheels and tires so advice is needed and appreciated.
Old Aug 21, 2009 | 02:22 PM
DrKillJoY's Avatar
Administrator
I've seen quite a few people use these, although on street, not track specifically.
You should also read up on "Hub-centric vs Lug-centric" so you don't wind up with vibration issues or worse.
Old Aug 21, 2009 | 02:24 PM
ZOOM ZOOM
will do thanks
Old Aug 23, 2009 | 11:51 PM
Josh18_2k's Avatar
ive never had a vibration issue with lug centric.
anyway, you're not running 275's up front. end of story.
on cobra wheels, the most you can get away with up front is 255/40/17, but you'll need spacers and/or fender work
275's will work in the rear unless you're lowered with corrected camber
Old Aug 24, 2009 | 09:01 AM
YaNi's Avatar
RIP Mark
You can probably get away with a 245 tire up front with coilovers.
Old Aug 25, 2009 | 11:36 AM
ZOOM ZOOM
thanks
Old Aug 25, 2009 | 03:53 PM
arrrex's Avatar
fender pull/roll with a baseball bat and a hammer works wonders. i fit a 9 in wide tire on my 240 doing that
Old Aug 25, 2009 | 05:42 PM
LargeOrangeFont's Avatar
Fistful of steel
I have 95 Cobra Rs on my car. 17X9 +24 all around on my car. You will need a 235/40/17 up front and a fender roll to get it to fit. If you don't want rubbing, you will need some negative camber and have to use coilovers, or camber plates.
You may be able to get the 275/40/17s in back with a fender roll. 245/45/17 will fit with no problem.
You can squeeze up to a 255/40/17 up front if you have coilovers.
See picture in my sig.
FB_Frank85
Sep 6, 2015 11:29 AM
