Need a stock FD brake rotor measurement
Old Aug 15, 2009 | 03:34 PM
spanks13's Avatar
If anyone has a stock brake rotor lying around I would really appreciate the help!
I need to know the thickness of the hub where the wheel bolts to. If you take some calipers inside the center hole and measure the thickness there I would really appreciate it!
I have a set of rotors I would like to try and use, but I need to know how much they will affect the wheel offset. If it is any wider than stock I will definitely be into the fender.
Thanks!
Old Aug 16, 2009 | 05:11 PM
spanks13's Avatar
They're 7 mm in case anyone cares
I stopped being lazy and took one off.
josef 91 vert
23
Sep 3, 2015 11:20 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 13, 2015 11:19 AM
