Might be 60-1?
Old Aug 5, 2009 | 09:50 PM
Hyper4mance2k's Avatar
The Shadetree Project
Might be 60-1?
I just got a new to me turbo, but I'm unaware of what model it is. It is a turbonetics, and the sticker on the back says T-11680. I searched all over the web, but couldn't find any info on it. Can anyone tell me what it is and the specifications on it are?
A compressor map would be awesome. The inlet on the turbo is 4" and the outlet is 2.5. and it looks like that exhaust is aright between 2.5" and 3" vband.
Took it apart to measure it. Well i had it apart I noticed something the compressor housing says 20190 60-1 on it, so it definitely has a 60-1 compressor housing on it. the compressor is a 14 blade with a 'T' and 'R' cast on it 76mm (3") exducer 57mm (2.24") inducer, and and the turbine is 10 blade 64mm (2.5") exducer and 74mm (2.9") inducer. t4 divided exhaust housing with a vband outlet I was told it was a 1.0AR, but there are no markings and noway to measure it.
It's going on my S3 13b with a small street port. How will this turbo perform? FYI I made 190whp NA with this engine, and I will be blowing through my 48IDA.
Old Aug 5, 2009 | 10:43 PM
ScorpionT's Avatar
Sounds like youre right, a full 60-1 turbo. If it is, the compressor should be a 59mm inducer. Everything else would be right for that turbo. It should do pretty well on your motor, wont make gobs of power or anything, but good for the street. It should max out around 400-425whp.
immanuel__7
89
Sep 5, 2015 10:23 AM
Megaspeed7
Rotary Car Performance
11
Apr 21, 2002 01:17 AM
fast13b
Mar 22, 2002 01:20 AM
mako
Nov 13, 2001 02:51 AM
