FJO sequential setup pics
Old Jul 29, 2009 | 11:52 PM
M104-AMG's Avatar
Since the FJO AI controller is "potted" I decided to place it above the cruise control on my Touring.
The AI nozzles/injectors were located as close as possible to my SMIC, in the hope of better atomization. More importantly, I didn't want to install a bung on the Greddy elbow. I left a some space so I can re-locatethe air-temp sensor along with a fast-acting one in the future.
I decided to use the front wiper-tank, so I got a new one and due to space constraints of the horn, I mounted the FJO pump on the passenger/left side using two custom fabricated brackets.
I tested to make sure gravity feeds the pump. I also "insulated" any place of rubbing or contact with the A/C condenser or PS lines using some old rubber hose.
While talking with FJO technical support, he suggested using RPM vs MAP for road/circuit use, as water delivery can grow as the RPM's increase plus boost.
He also suggested using the "tach" signal vs. the coil/ignitor signal, as a true tach signal is cleaner.
Due to the location of the pump, I did have to cut a small piece for the lower panel to clear and fit in all mounting holes.
Zip-ties are your friend.
Hope it helps!
:-) neil
Attached Thumbnails FJO sequential setup pics-fjo-controler-cruise-control.jpg   FJO sequential setup pics-fjo-nozzle.jpg   FJO sequential setup pics-fjo-nozzle-alternate-view.jpg   FJO sequential setup pics-fjo-pump-front-spoiler.jpg   FJO sequential setup pics-fjo-pump-mount.jpg
Old Jul 29, 2009 | 11:53 PM
M104-AMG's Avatar
More pics.
:-) neil
Attached Thumbnails FJO sequential setup pics-fjo-pump-mount.jpg   FJO sequential setup pics-fjo-pump-mount-rear-bar.jpg   FJO sequential setup pics-front-wiper-resevoir-pump-background.jpg
Old Aug 8, 2009 | 11:27 PM
M104-AMG's Avatar
This reliability mod really kept engine temps down while on the track, last weekend.
It was 93-F, and 85% humidity, and the car would do two (2) twenty-minute (20-mins) sessions back-to-back, and the most the water-temp would get on the track was 215-F.
After a cool-down lap, she would be running about 210-F, sometimes 200-F, with 100% distilled water.
We tried 35% methanol, and she ran too rich.
The exhaust tip is looking very clean now.
:-) neil
Old Aug 10, 2009 | 07:51 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
thanks Neil and congratulations. i would like to post this in the big thread in the 3rd gen section so more owners can benefit.
actually, i would prefer it if you were to post it. the community NEEDS real world testimonials.
link: https://www.rx7club.com/3rd-generation-specific-1993-2002-16/making-case-rotary-powered-fd-fix-806104/
road racing is THE most challenging venue for the turbo'd FD and it is great you were able to tame the thermal beast.
howard
Old Aug 10, 2009 | 07:59 AM
BTW, i suggest 2 oil coolers...
hc
Old Aug 10, 2009 | 05:50 PM
M104-AMG's Avatar
hc
Howard,
thanks for the kind words.
I already have installed two (2) stock oil cooler.
I'll post a write-up and some pics soon.
An update on the installation:
1) the water/meth injector was turned 90-degrees to better clear the hood;
2) the FJO "blackbox" was re-located under the cruise-control towards the firewall, using one of the cruise-control screws to mount.
BTW: I also just hooked-up my Innovate wide-band, and an extra bung for EGT temps . . .
:-) neil
Old Aug 8, 2011 | 11:34 PM
M104-AMG's Avatar
UPDATE: the last two events (Roebling Road and Grand Prize of America) were both in 102+F (heat index of 110-F)with 90%+ humdity, and I was hammering on the car (stock sequential turbos running 14-lbs).
As such, water temps were 245+F with oil temps at 220F (dual R1 coolers). This was with synthetic oil (OMP removed), Koyo Radiator, 30% antifreeze, factory A/C, and running 100% distlled water.
I then tried it with a 50% methanol and 50% distilled water, and my water-temps went down to 220-F, and oil-temps were 210-F.
:-) neil
apooch
Sep 4, 2015 10:27 AM
