Rotary Drag Racing The place to post your racing stories and info
FB control arms
Old Jul 22, 2009 | 02:39 PM
holtjohn's Avatar
FB control arms
Does anybody make adjustable upper controls arms for a FB? I want to change my pinion angle to see if I can get my car to hook better, I have search but all I seem to find is FD stuff. Any help would be great. Thanks
Old Jul 22, 2009 | 02:50 PM
Viking War Hammer's Avatar
*** Bless The USA
Not sure, but they aren't hard to make.
Just get you some aluminum stock, 8 rod ends, a tap and some shims to fit the rod ends into the stock chassis brackets nice and snug.
Old Jul 22, 2009 | 02:52 PM
holtjohn's Avatar
I was thinking about building some but I dont want to mess up and die. I also need new bushings and figure that new control arms would have them already.
Old Jul 22, 2009 | 02:59 PM
*** Bless The USA
So, you don't want solid rod ends?
Chris Alston makes some nice urethane rod ends.
Old Jul 22, 2009 | 03:04 PM
holtjohn's Avatar
Oh ya I would, I bought the stuff to do it once acttually but ended up sending it back cause they sent me the wrong size tube.
Old Jul 22, 2009 | 03:08 PM
holtjohn's Avatar
the only thing im worried about is that rod end have a 20 degree angle and im not sure what the rx7 arms are angled at.
Old Jul 22, 2009 | 03:10 PM
*** Bless The USA
Here you go, http://mrcmfg.com/catalog/product_in...products_id=67
It's more expensive than a DIY but you probably knew that already.
Old Jul 22, 2009 | 03:11 PM
*** Bless The USA
Bah, that's just the lower.
Old Jul 22, 2009 | 03:12 PM
holtjohn's Avatar
see that is the lowers I need the uppers. Im not sure why they make the lowers that only changes the wheel base.
Old Jul 27, 2009 | 04:47 PM
bwaits's Avatar
Needs More Noise
Are you using stock pickup points on the chassis and rear end? The upper arms can not be done if so. They will bind the suspension up and crack the chassis pick up points.
-billy
Old Jul 28, 2009 | 01:14 AM
holtjohn's Avatar
-billy
Why is that?
Old Jul 29, 2009 | 06:58 PM
holtjohn's Avatar
Anybody else want to chime in here on this?
Old Jul 29, 2009 | 07:21 PM
*** Bless The USA
I don't see how they would bind, I could see them cracking but some battle boxes would fix that.
Old Jul 29, 2009 | 07:28 PM
hella24's Avatar
rotor toter
You will have to get rid of the watts link and replace it with a tri link.( and panhard) You can adjust the pinion angle with the tri link ends. This modification eliminates the two upper arms completely. I use this set up with a panhard bar and the lower control arms from Billy at RESPEED. He makes great parts.
If you lower the car without adjusting the pinion angle you will wear it out prematurely.
I see now this is in the drag racing section. I use this set up for road racing. I am not sure how well it would hold up under repeated violent launches. You have wider tires, more hp, etc.
Old Jul 29, 2009 | 08:47 PM
rex3's Avatar
E85+Boost+Rx2=zoom zoom
What are battle boxes?
Old Jul 29, 2009 | 09:17 PM
holtjohn's Avatar
x2
Old Jul 29, 2009 | 10:22 PM
jccNV's Avatar
Ck this pic's
http://7sinsracing.com.au/new-galler...detail-images/
that car run's 9 sec.
Old Jul 30, 2009 | 12:21 AM
holtjohn's Avatar
Nice find, but I think they made theirs, I guess I might have to also.
Old Jul 30, 2009 | 05:12 PM
*** Bless The USA
http://www.mikefordmustang.com/write...ll-mustang.php
Old Jul 30, 2009 | 06:14 PM
rex3's Avatar
Cool... Man they have everything made for fords. Looks pretty easy to fab them for our cars.
MattGold
Sep 9, 2015 02:20 PM
