MSD ignition problems
Old Jun 3, 2002 | 05:51 PM
RiceRocket's Avatar
Livin loud like TIMMAAAYY
Unhappy MSD ignition problems
the MSD ignition box i have in my car is not hooked up and it came with the car when i bought it. if the box is messed up, will it in turn mess up anything on my car? is there any way to check and see if the box is fully functional
Old Jun 3, 2002 | 06:21 PM
RETed's Avatar
Royal pain in the *** to test...
The way I usually check is to hook-up all wires, except for the thin white wire - you'll need a coil for this.&nbsp Run a spark plug wire into the coil (makes this part easier) and put the other end close to a "ground" point.&nbsp Now, once everything is hooked up, touch the thin white to "ground" and then lift - when you lift the thin white off, you should see/hear a zap from the spark if the box still works.
-Ted
Old Jun 3, 2002 | 06:38 PM
RiceRocket's Avatar
if the box doesn't work adn i still hook it up, what is the worst that could happen?
Old Jun 3, 2002 | 06:49 PM
RETed's Avatar
Nothing...you'd get no spark.
-Ted
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
meetRoX7e
Sep 11, 2015 11:09 AM
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
