Rx7 RPM warning malfunction
Old Jul 16, 2009 | 05:15 PM
jeffro11's Avatar
Exclamation Rx7 RPM warning malfunction
Hi all, since my last post here a long time ago, I switched out my old engiine, the rotor housings were REALLY scored. Anyways, I got a rebuilt engine, all has been well for nearly a year.
On to my problem... Today my RPM warning buzzer has been turning on whenever I turn my steering wheel to the RIGHT and my speed is ABOVE 40km/h. It then stops when my RPM exceeds 5800RPM.
Is this a short in the column causing this? How can I disable the buzzer. Any reply would be GREATLY appreciated, its ear-piercing loud. I've searched everywhere and no one seems to be having this issue.
Thanks.
Old Jul 17, 2009 | 09:13 AM
Aaron Cake's Avatar
Engine, Not Motor
Check your oil and coolant level.
Old Jul 17, 2009 | 03:31 PM
jeffro11's Avatar
Hey Aaron, that was the first thing I checked. Both were full.
There was a loose connector under my dash (the clip is broken). I taped it up and went for a drive, all is fixed...
Thanks for the reply!
Old Jul 17, 2009 | 03:54 PM
mazdaverx713b's Avatar
Have RX-7, will restore
for reference, what year was the 7 and where was the connector needing to go to?
Old Jul 18, 2009 | 01:09 AM
jeffro11's Avatar
Its an 86 N/A. The connector looked like it was going to the cluster from the main harness right beside the column. It's such a rats nest in there from when the previous owner installed the fuel switch. I'm sort of scared to find what else the previous owner did to the car other then killing the previous engine.
All I know is that my problem is fixed, maybe it is a coincidence. I'll be sure to post if this happens again. The warning still works, so.... I'm not going to investigate further.
Jeff
Kyo
Apr 13, 2019 09:24 AM
Th0m4s
Feb 26, 2019 02:04 AM
FührerTüner
Time Slips and Dyno
38
Nov 8, 2018 04:13 PM
