im lost
Old Jul 11, 2009 | 11:33 AM
TTT86's Avatar
gen II
FL im lost
i just purchase a '89 rx-7 13b n/a can not get it to start up. has spark, and fuel. need help. cover is off of maf sensor at aftermarket air filter. possibly flooding cyl. never worked on rotary before so any help on where to start would be appreciated.
Old Jul 11, 2009 | 10:20 PM
farberio's Avatar
NASA-MW ST4
If its flooding it will feel as though the motor makes no compression. To deflood remove all of the spark plugs and crank unplug the Crank Angle Sensor (CAS), crank till no more fuel exits the motor and re install everything.
You may want to try a new mass airflow sensor (MAF), its wierd that the cover would be off. Testing procedures for the MAF are in the Factory Service Manual (FSM), you will need a digital multi meter.
Old Jul 11, 2009 | 10:46 PM
misterstyx69's Avatar
Retired Moderator, RIP
The Afm should only be disconnected by Undoing the Clip/Connector..If someone has Screwed with it by opening it Up from anywhere else,chances are it is Toast..get the "N" number off it..Post a Wtb in the sec Gen section
Old Jul 11, 2009 | 11:31 PM
farberio's Avatar
NASA-MW ST4
As misterstyx said, and read my post sing air flow meter not mass air flow sensor.
Old Jul 13, 2009 | 10:18 AM
TTT86's Avatar
gen II
i appreciate it yea i did the dreaded compresion test and found 50 psi on the front and 0 in the rear. so yea rebuild time.
Coochas
44
Nov 5, 2019 11:08 PM
Coochas
Oct 3, 2015 04:49 AM
TrboMike
NE RX-7 Forum
Sep 28, 2015 09:40 PM
Devon Murray
Sep 25, 2015 09:41 AM
