Issues with the SA
Old Jun 29, 2009 | 04:19 PM
golden80's Avatar
Exclamation Issues with the SA
When I idle its less than 1k rpms and when I take it out of the driveway, i can floor it and it may creep up to 20-25 mph. I recently replaced the battery and the spark plug wires and now it also wont start when I have the wire attached from the cap to the T2 plug. If its plugged in, the battery sounds like it shorts out and if it isn't plugged in, the engine turns over quickly. Also, it oddly can be started without the clutch depressed.
Old Jun 29, 2009 | 06:48 PM
Aaron Cake's Avatar
Engine, Not Motor
You need to rewrite your post so that it makes sense.
For example, the car is supposed to idle below 1000 RPM. 750 +/- 50 RPM is the factory idle speed.
How does a battery sound shorted?
What exactly is the problem you are having? Are you sure that all the plug wires are in their correct locations?
Old Jun 29, 2009 | 10:26 PM
golden80's Avatar
Sorry about that.
When I move the key to the on position, the radio starts, dash lights turn on, and the electrical works. When I turn it to start, it doesn't crank and all the electrical components turn shut off, I hear a pop that sounds like it comes from the battery and wont come back on until the leads are removed and put back on the battery.
The problem is that the engine turns over and will run if I remove the T2 spark plug wire, but if I attempt to drive it, the engine will rev VERY slowly. Takes about 10 seconds of flooring the gas pedal to get it to 2.5k rpms.
And yes the cables are all connected correctly.
Old Jun 30, 2009 | 08:43 AM
Aaron Cake's Avatar
Engine, Not Motor
First thing to check are the battery cables themselves. Are you sure they are not corroded?
Check the ignition leads to make sure they are going to the correct plug. Sounds like they aren't.
Check the carb secondaries to make sure they are opening.
Old Jun 30, 2009 | 10:30 AM
golden80's Avatar
Thanks a lot. Turned out to be the battery cables. Runs like a champ now
rgordon1979
40
Mar 15, 2022 12:04 PM
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
betes
Sep 27, 2015 08:25 AM
Steven_McKinley
Sep 5, 2015 10:48 AM
