My New 87 turbo II pics
#126
and probably new side seals and springs
3mm solid cornner seals
and a large streetport so i don't have to run so much boost.
might change a little but thats what im thinking ^^
i also figured out that i have a "cheater box"
but 15-16 psi of boost is way to much for that
previous owner was running 20 psi on it then changed it to 10
probably why its blown
#130
HKS obsessed
on
Don't run 3mm apex seals, from what I've read they don't even work and are no where near the money. Even if they were if you're running on low boost you won't need them. Have you looked into the 2mm super seal? Or if you're running real low boost stock will be more then sufficient.
#131
i talked to atkins and i think im going with 3mm. the groves are pretty worn out. dan said its best to start over with the 3mm seals. because the 2 piece apex seals were trying to fit into the three piece's worn slots. is what he said
#132
No money. No love.
on
^In the end it may be cheaper to just buy newer rotors. Machine work breaks the pocket...then again I have 3mm seals too
Clean lookin car. Good to see another knowledgeable person with a 7.
#133
my dads bussniess partner and best freind owns a machine shop. he is very good and can machine the rotors for us.. we help each other out.
how are you going to know if the rotors are newer? probably can't.. think i will go 3mm route before i buy new ones.
Question
best street port templates for intake?
best template for exhaust?
Atkins says they use racing beats streetport template for intake.
opinions?
Question
opinions?
#134
HKS obsessed
on
Everyone here that I know that has done their own rebuilding and streetporting has used the Racing Beat templet for intake, and the Rineapple Racing EP3 or Racing Beat for exhaust. The Mazdatrix DVD works really well to teach you the best way to do all the porting as well.
#135
on
Question
opinions?
Question
opinions?
#137
Is this car running on the stock ecu? If so, and running a aftermarket turbo that's pushing much more air into the motor as compared to the stock turbo at the same boost the air is much more dense and the ecu wont compensate for the added air since it thinks your running the stock turbo, that's more then likely why your motor went...
After your build is finished, buy a Rtek or a full standalone and get it tuned, you will be very happy and you wont blow another motor.
#141
on
Bummer about the engine going boom.
I have to go across the grain and say I don't really like the wheels. Too big to start and not big on the style.
Good luck with the rebuild.
#142
Thanks we got the ports machined today yay.
and the wheels i actually like they look better in person plus i don't have the cash to change them anyway. haha
#143
on
Haha. I've been there before.
As long as you like them that's all that's important. They aren't the worst I've ever seen...just not my style so much.
Keep up posted on the rebirth.
#145
oh pinnaple racing medium turbo intake port and the #pea exhaust or W/E need to up date thread maybe sometime soon. ports are hard to take pictures of but they look pretty dam good ! exhaust isn't done quiet yet
#146
allright it is due time for a update
.I got the upper & lower intake manifolds Glass bead blasted ( soon no be cleared )
Block off plates coming :P
. porting is done on the Irons looks very good although i forgot to take a picture of it before i started tapping. lol irons are a high heat black and high temp clear coat. Fresh today
. started on the exhaust ports got one side done. tell a difference???
. Got my parts !!! from atkins. about time.
#149
no turbo is fine. im rebuilding the tranny tho.
update: painting lots and lots of parts waiting for the machine shop to finish my rotors. then we will be ready to put her back together minus fitting the side seals.
