NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
Will I pass NY State Emissions?
Old May 13, 2009 | 11:46 PM
s1mpsons's Avatar
HamfistRacing.com
Info on the car:
Turbo Back 3" exhaust
Single High Flow Metallic Substrate Catalytic Converter 3"
850cc Injectors x 4
280 lbs/hr Fuel Pump
PFC w/ Tune
Stock Air Pump (air feed to catalytic converter deleted)
Ram Air Intake
Thanks!
Old May 14, 2009 | 02:14 AM
2RotorsNaDream's Avatar
¿¿What are pistons??
No offense but we're in NY, who cares?? Hahaha, just pay to get it done like everyone else in NY on this forum.
Old May 14, 2009 | 02:31 AM
SPEED_NYC's Avatar
RX-Parts
exactly, pay the $100-$150 and get it done, why take a chance of it not passing when you can buy a guaranteed sticker?
Old May 14, 2009 | 06:15 AM
Rob XX 7's Avatar
FC guy
I know the state knows it goes on, but am I just too old school that I think certain things should not be discussed on a public forum?
Old May 14, 2009 | 11:24 AM
We didnt post any spots that do it so I dont see a problem with it.
Old May 14, 2009 | 11:35 AM
s1mpsons's Avatar
HamfistRacing.com
No offense but this is all off topic.
Old May 14, 2009 | 03:01 PM
AnthonyNYC's Avatar
Stay tuned...
You can have a perfect setup and have bad plugs or tune that's too rich and still fail so no one is going to be able to tell you on a forum if you can pass or not. Take it to an inspection station and find out. Keep in mind they check for everything, not just emissions.
Old May 14, 2009 | 04:58 PM
It all sounded on topic to me. Im just curious why you dont just wanna pay and guarantee a pass instead of risking failing. Rotary is so finicky even stock, so its a good chance you'll fail.
Old May 14, 2009 | 10:58 PM
s1mpsons's Avatar
HamfistRacing.com
I posted to find out, not about how to get around the emissions test, but whether or not similarly set up cars have passed (without paying off the tester). I'm not asking anyone to say I'll pass with 100% certainty here. I just want to know what has happened to others with similar setups.
Old May 15, 2009 | 12:02 AM
93rx74lyfe's Avatar
Ronald..
I dont live in NY but with those mods here in VA I'm fairly certain you would fail the test.
Old May 15, 2009 | 12:52 AM
ALNY93R1's Avatar
You don't have a chance without the air feed to the cat.
Old May 15, 2009 | 02:56 PM
s1mpsons's Avatar
HamfistRacing.com
Keep in mind this is not a ceramic substrate cat like the bonez or OEM unit. The air pump still throws air into the system to burn the extra fuel. Backfires like a bitch when I run the air pump.
Old May 19, 2009 | 07:05 AM
ramello's Avatar
since when do we have emissions in ny?? ive lived here my whole life (cept 2 years in socal) and ive never had to take my car to an emissions test
Old May 19, 2009 | 08:14 AM
Rob XX 7's Avatar
FC guy
15 years ago I used to keep my cars registered upstate to avoid emissions testing. Guess it is still like that.
Safety only in certain areas.
Old May 19, 2009 | 12:23 PM
ALNY93R1's Avatar
Yeah , no emissions for me also
Old May 19, 2009 | 01:40 PM
s1mpsons's Avatar
HamfistRacing.com
They don't put the FD on the dyno rollers for annual NYS inspection? Why not? Because its 15+ years old?
Old May 19, 2009 | 01:44 PM
s1mpsons's Avatar
HamfistRacing.com
http://www.nysdmv.com/vehsafe.htm
1996 + requires emissions testing. Pre-1996 requires visual inspection of emissions equipment.
Old May 19, 2009 | 04:49 PM
s1mpsons's Avatar
HamfistRacing.com
^^^ That is bogus information. Not only do I need to be on a sniffer, NY metropolitan area has more strict emissions standards.
Anyone run on the sniffer with Drygas in the fuel tank?
Old May 19, 2009 | 06:11 PM
Rob XX 7's Avatar
FC guy
I think the law states that if your car is pre 1996 and it has something in the emissions missing you can pass so long as the car passes the sniffer.
The logic being that some OEM equipment is not availible anymore.
Newer cars they just plug in to the OBD port and the computer tells the machine how your **** is doing.
23Racer
Canadian Forum
Sep 18, 2015 11:10 AM
JP's 93 fd
Sep 16, 2015 01:12 PM
