Portland ORPCA AutoX event on 5/10/2009
Old May 11, 2009 | 09:40 AM
jkstill's Avatar
Searching for 10th's
Default Portland ORPCA event on 5/10/2009
Lots of fast drivers at this event.
Kudos to josh18_2k for 7th fastest time at 39.259.
Josh fell from 3rd at the last event.
I didn't manage a top 10 at this one, coming in 17th with a 41.088.
Is is just me, or were there more fast drivers at this event than the last one?
Here's a link to some PCA videos from the event: http://www.oregonpca.org/events/auto...ax2/ax2-media/
Here a couple videos I took with the new GoPro Here Wide Angle camera:
First run: http://www.youtube.com/watch?v=kJzaBMjIWBI
Fastest run: http://www.youtube.com/watch?v=w9Qpy51Cvfg
Looks like I needs to shift to 1st in 1 or maybe 2 places to get out of the two tightest corners. Should have tried it and didn't.
At the last event using 1st cut nearly 1 second off my time in a tight corner.
I would prefer a new LSD with a 4.77 gear set, but shifting to 1st is quite a bit cheaper.
Old May 12, 2009 | 11:34 PM
xenocide's Avatar
01000101
nice. I need to get out to one of those. Do you need inspection for the autoX?
Old May 15, 2009 | 02:34 PM
jkstill's Avatar
Yes. Mostly it's to make sure of just a few things
* no bad wheel bearings ( SCCA checks this , PCA does not)
* battery is securely mounted.
* you have an approved helmet
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
gabescanlon
NW RX-7 Forum
Sep 24, 2015 11:08 PM
gabescanlon
Sep 15, 2015 06:57 AM
gabescanlon
Sep 14, 2015 12:03 PM
