Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek possible rtek issues
Old May 10, 2009 | 08:21 PM
13b-series's Avatar
So heres the story. I went to the gas station last weekend and it ran fine on the way there, after i filled up it ran like crap like it was loading up at bottom end and smoking like there was extra oil in the premix. I've been checking things that could be causing issues like possible vac leaks. Last nite I noticed its still doing the same thing, so I went to check codes on my rtek and 5 things poped up then disappeared(didnt get to clear them myself) an all I caught was coolant temp sensor. So I backed out of the diag menu, waited then went back into it. This time there was 4 codes on the menu and I was quick enough to only catch the first one which I think was afm temp sensor. Is there an issue with my ecu clearing codes on its own or is there something else that I need to look into?
Old May 10, 2009 | 09:29 PM
boostedfc3s's Avatar
1.3 liter piston eater
Maybe you got bad gas. Does your exhaust smell a little like diesel ? I had this happen to me a couple of years ago. Went and filled up my tank and two blocks down the road it was running like crap and smoking. I got out and smelled my exhaust and it had a very light scent of diesel. I went back to the gas station and showed the manager. She called me the next morning to let me know the tanker that was there that day dropped 1000 gallons of diesel into the premium tank. Drained my tank, changed my fuel filter, new plugs, and 5 gallons of premium from a different station and everything was back to normal.
Old May 10, 2009 | 10:55 PM
drifting in drifting's Avatar
i would have freaked out good way to lose an engine
Old May 11, 2009 | 11:28 AM
turbo2ltr's Avatar
What version of the software are you running? What ECU version do you have (shown at the top of the ECU Setup screen)
I highly doubt its the ECU clearing codes, but just a display issue with the software. New error codes are received and displayed every second. If the codes disappear right away, it probably means the codes that do flash are just crap left over in the Palm's memory and as soon as it gets an update from the ECU (which is no codes) then it updates the screen.
Old May 12, 2009 | 01:35 AM
13b-series's Avatar
boosted - I have kinda noticed a diesel smell finally, since its been a bit windy. May have to do the same.
turbo2ltr - software is v2.1.0 and the ecu is a N332. Ok, I didnt know or remember that from reading the manual on the rtek. Thanks for the info, got more stuff to look into then.
rgordon1979
40
Mar 15, 2022 12:04 PM
WyomingTII
Rtek Forum
Oct 26, 2015 05:26 PM
betes
Sep 27, 2015 08:25 AM
Monsterbox
Sep 11, 2015 03:29 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
