What turbo are you running with HKS cast manifold???
Old May 10, 2009 | 01:03 AM
quick_spoolin's Avatar
I'm Single..Turbo that is
Arrow What turbo are you running with HKS cast manifold???
I am running a T04E and it has lived its life. It is worn out and smoking, so it's time to upgrade. I am looking at PT6262, PT6265, GT4082, or the GT4088. These will hopefully clear my intake and my frame rail. So I figured I would ask you folks on what you’re using to see what options are out there. My motor is a half-bridge with all the supporting mods. I am currently running 14psi but I am bumping up to 18psi with the new turbo. My driving style is spirited street driving with the ever so often 1/4 mile track day. I am looking for something with fairly good spool and one that will keep up with the top end power of a half-bridge.
Thank you
Old May 10, 2009 | 01:06 AM
Andrew777's Avatar
Rotating
If your going with the garrett line go for the gt4096r, you won't be happy with the slow response of the 4088, I know the dual ball bearing is more money but it's worth every penny
Old May 12, 2009 | 01:38 AM
slpin's Avatar
7th Heaven
the GT40 non ball bearing *does fit*
your passenger brake line will become too hot to touch.
the ball bearing ones?
it should fit
who knows
this ******* broke
Old May 12, 2009 | 01:46 AM
it should fit
who knows
this ******* broke
Whats your motor setup? Ported? How much boost and what RPM does that thing spool up at?
Old May 12, 2009 | 05:57 PM
slpin's Avatar
7th Heaven
ported. moderate street. all 4 runners polished. 106 ar. ext gate at 1 bar and it does not open up the gate at 1 at gear. set at 1 bar. it full boost around 5 at 3rd. feel boost around 4
Old May 12, 2009 | 07:53 PM
Sesshoumaru's Avatar
Tenseiga
Turbonetic 62-1
BB and Water cooled
Old May 12, 2009 | 08:28 PM
Wow that is laggy!
Old May 12, 2009 | 08:30 PM
Originally Posted by Sesshoumaru
Turbonetic 62-1
BB and Water cooled
How do you like this turbo? Do you have any port work? How much boost are you running and when does that turbo spool up? I was looking at getting this turbo. I talk to Presicion Turbo and I think im going to go with the PT6265SP billet turbo.
Old May 12, 2009 | 08:49 PM
slpin's Avatar
7th Heaven
I do believe the design of the manifold plays a big role in it's unrespinsuveness. it should wake up a bit after Steven Kan tunes it tho
Old May 12, 2009 | 11:13 PM
SmogSUX's Avatar
No money. No love.
Anyone with an HX40 running this manifold? How's the fitment?
Old Jun 19, 2009 | 06:46 PM
Correction. I have a t-66 that is crap, but not any more!!!! I ended up buying a new HP66 and I love it!
dkwasherexd
May 27, 2017 04:51 AM
