Microtech Couple of Sensors i cant figure out
Old May 9, 2009 | 05:43 PM
BurntOrangeT2's Avatar
No phonebook but OG calls
I have a S4 TII motor using a LT10S to run it and i cant figure out what the Knock Sensor or the BAC hook up to as in which wire, so just want to know if they arent needed or where they should go.
Thanks
Old May 9, 2009 | 06:38 PM
rx72c's Avatar
Top Answer: 1
they dont.
Old May 9, 2009 | 07:38 PM
alright thanks again rx72c
Old May 9, 2009 | 08:38 PM
hate to be a pest but why dont these sensors do anything when you run a microtech LT series ECU?
Old May 11, 2009 | 07:33 PM
pistones's Avatar
LT's don't use those inputs. they should but don't
Old May 11, 2009 | 10:42 PM
so what about a knock sensor that seems pretty important for a turbo engine and the coolant that flows through the throttle body im so confused.
Old May 12, 2009 | 06:52 AM
rx72c's Avatar
Top Answer: 1
Knock sensor is important but a microtech is a very basic computer.
Their is not much more to it.
As for bac, Its important and very useful but microtech not designed to use it(unless you request when you purchase).
Old May 12, 2009 | 12:24 PM
So what should i do about a knock sensor? do you yourself run one externally or is there an option to have the microtech interface it, do you run one or reccomend something..
What do you reccomend with the BAC valve? Leave it open all the time, block it off, send the unit back to microtech?
Old May 12, 2009 | 05:27 PM
rx72c's Avatar
Top Answer: 1
I have blocked the BAC and my car idles at just over 1000rpm with no worries.
Idles 800rpm cold no worries.
As long as you have good comp it will run fine without.
As for the knock sensor. I have an external system. Knock is very important to log especially when you run 30psi on pump fuel lol.
Old May 12, 2009 | 05:42 PM
13BT_Starlet's Avatar
What system are you using to log knock sensor?
Old May 12, 2009 | 06:05 PM
where can i purchase this external knock system and the logger for it good sir.
Old May 25, 2009 | 04:35 PM
Ttt
Old May 25, 2009 | 11:52 PM
mattmarrx3's Avatar
link make one not sure if this site is right but have a try
http://www.linkecu.com/products/TuningTools
Old May 25, 2009 | 11:54 PM
mattmarrx3's Avatar
or www.nzperformance.co.nz paul can get it for you even if its not on his site he can get it
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
SCinfidel
Sep 8, 2015 05:36 PM
whinin
Sep 5, 2015 11:52 PM
