Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
3rd spark plug
Old Apr 12, 2009 | 01:59 PM
mav248's Avatar
3rd spark plug
Hello,
Im currently in early stages of producing a 4 rotor (currently sourcing parts)
Is a 3rd spark plug like the r26b worth it?
Jeff 20b left a reply on someone elses post a while a back that wasnt worth it. Does it increase MPG since? Does it increase the burn? Should it fire with both other spark plugs at the same time it should it have a delay? Shall i leave the 3rd spark plug idea alone?
Old Apr 13, 2009 | 12:22 AM
nillahcaz's Avatar
you are missed
do a search for "spark split" this will tell you that you do not want the two plugs to fire at the same time for the most power output. Now the fun part's what to do with the water jacket you want to put a plug into and how to control three ignition events for 4 rotors. It not done a lot as the gain is small for the cost.
Old Apr 28, 2009 | 04:37 PM
g14novak's Avatar
The Doctor
IMO, its really used to make sure you get the full spark out of every drop of fuel that's in the combustion chamber. If your trying to reach the highest hp #'s possible, this will show a small increase. But it's a lot of work for the small gain you'd get over having 2 spark plugs.
And as stated earlier, you also are going to have to program something to control the ignition of the 3 spark plugs firing all 4 rotors at the correct timing.
Old Apr 30, 2009 | 02:59 AM
Hyper4mance2k's Avatar
The Shadetree Project
The 3 spark plug per rotor setup offers almost no more power, only only helps with fuel economy.
http://www.scribd.com/doc/7062188/Ma...-Engine-LeMans
Old Apr 30, 2009 | 12:46 PM
fidelity101's Avatar
Rallye RX7
good link!
Old Apr 30, 2009 | 09:38 PM
I do what I can.
Old May 16, 2009 | 03:34 AM
Jeezus's Avatar
Stu-Tron Get Yo Groove On
Old May 16, 2009 | 04:06 PM
Lasse wankel's Avatar
See my new "Sweden made 3rd spark plug dyno test"
/Lasse
rgordon1979
40
Mar 15, 2022 12:04 PM
ZacMan
Sep 19, 2015 09:20 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
