found a 808
Old May 26, 2002 | 10:17 PM
projectsupra's Avatar
found a 808
I found a 808 forsale
but what is it I searched for pics cant find any I found alot of part websites listing rx3/808 are they the same?
Any pics?
Old May 26, 2002 | 11:11 PM
Keep to the right.
Yeah the 808 is the piston version of the RX-3...so for finding pics look for RX-3.
http://www.vision.net.au/~bhaslam/rx3_cars.htm
Old May 27, 2002 | 09:02 AM
rxrotary2_7's Avatar
yes the same car only piston powered from factory. buy it.
there are some small differences, but nothing you cant overcome.
Old May 27, 2002 | 11:28 AM
Keep to the right.
A kid I knew in high school was given an 808 wagon by his school BUS DRIVER! It was a rust bucket though and he didn't even know what brand of car it was becuase all the badges had fallen off. One day he forgot to set the hand brake and it rolled out of his drive way and hit a tree. I should find out if his family still has it, maybe there's still some good trim or something.
Old May 27, 2002 | 10:13 PM
peejay's Avatar
Old [Sch|F]ool
They have different noses, don't they? So the front won't look the same as an RX-3.
The 808 turned into the rear-drive GLC which was sold until about '84 or '85 or so. I want one of THEM
Old May 27, 2002 | 10:14 PM
Felix Wankel's Avatar
Super Newbie
The taillights are different too.
Old May 27, 2002 | 11:29 PM
things that can be changed....
Old May 28, 2002 | 11:49 PM
Kill No Cone's Avatar
The 808 has a differnt front K frame than the Rx3, so and engine swap will take some engineering. I have heard that they have a lower rear gear ratio but I am unsure about that.
Old Jun 2, 2002 | 04:08 PM
rxtasy3's Avatar
Ok, mine is an 808. I did the swap and it aint ****. U remove the engine mounts from the 4cyl and the mount for the rotary bolts up with the sway bar, add another hot wire for the extra coil and done. Mine is a '75, the nose change in '76 to 2 lights instead of 4. Tail lights r different also from what is in the 3. The manufacture date on mine is 1/75 and is as close as u'll find to the rx3 right down to the guages.
Old Jun 2, 2002 | 05:09 PM
Thank You! that is what i was trying to say.
Old Jun 2, 2002 | 05:42 PM
rxtasy3's Avatar
sorry for the double post, don't know what happened.
Old Jun 3, 2002 | 07:31 AM
took care of that double-post.
Bauer778
Nov 4, 2015 04:42 PM
GreyBush
Sep 14, 2015 01:29 PM
GreyBush
Sep 12, 2015 02:23 AM
