What boost controler for dual wastegate setup ???
Old Mar 20, 2009 | 01:09 AM
Romanator's Avatar
I'm looking into buying a boost controller withing the next 2 months. I have a custom manifold with dual wastegates. I know I'm not the only one here with a dual wastegate setup. Just wondering what kind of electronic boost controllers would be recommended for this type of setup ?
Old Mar 20, 2009 | 07:11 AM
glenrx7's Avatar
Building my car...
I am running dual wastegates and have decided to run the eboost2 controller from turbosmart. They are really nice, the have several really cool setup features such as gear tunable boost points...
The greddy profec B is less money and a whole lot less complicated , yet you loose some pretty cool funtions, however it will controll dual gates.
just my 2 cents
Old Mar 21, 2009 | 11:07 PM
Romanator's Avatar
thanks for the info. Besides eboost2 and greddy profec B is there any other ?
Old Mar 22, 2009 | 01:14 PM
ScorpionT's Avatar
Apexi AVC-R is the best Ive used. The only thing is, you will probably need an Apexi dealer to tune it, they are pretty complex.
Old Mar 23, 2009 | 11:54 PM
Romanator's Avatar
Mr.ScorpionT you say the Apexi AVC-R is the best you've used. Do you have a dual wastegate setup ?
Old Mar 24, 2009 | 11:12 AM
ScorpionT's Avatar
Full Race Supra manifold with dual Tial 44mm
Old Mar 25, 2009 | 09:56 AM
spr258's Avatar
I second the eboost2. Great boost controller and has tons of features. I bought a greedy profec B off someone on the forums and it didnt work. So I got the turbosmart and it is easy to switch presets and i still havent seen all the features. BUT I dont have duel wastegate setup though
Old Mar 25, 2009 | 10:40 PM
elwood's Avatar
I'm controlling my dual TiAL 44 WGs with my MoTeC. I'm using the MoTeC solenoid.
How is controlling two WGs any different than controlling one of them? If the solenoid flows enough air, just Y them both together in parallel. That's what I did, and it works fine.
Skeese
65
Mar 28, 2017 03:30 PM
