Drifting Discuss Drifting and drifting techniques here.
FC3S springs/shocks suggestion
Old Mar 19, 2009 | 02:50 PM
ruddyrid's Avatar
Doin' Work Son!
im looking at a simple spring and shock set up, since coilovers are now out of my budget
i think for shocks im going to go w/ Koni Sport Yellow or maybe Tokico Illumina, but im leaning more towars the Koni even if they are more expensive and difficult to install.
for springs im looking into the ones i listed below. if anyone has any suggestions that would be great. and no, dont suggest suspension tech., racing beat, or even eibach, tho they do make a good product. unless of course u know what ur talking about feel free to school me.
for springs i think im going to get RS-R Race springs, maybe the RS-R SUS springs since the koni's are pretty intense from what ive heard. the Tanabes seem good but they might be a bit soft
so if u have any of these springs or dampeneres, even if in a different make, plz let me know what you guz think about them.
l8z
-Tanabe GF210
rate
f: 3.0kg/mm[170lbs/in] / r: 2.5kg/mm[135lbs/in]
drop
f: 1.5"[?] / r: 1.5"[?]
-RS-R Down SUS lowering springs #30-M100
rate
f: 3.6kg[205lbs] / r: 2.2kg[125lbs]
drop
f: 1.4" / r: 0.8"
-RS-R Heavy Duty "Race" lowering springs #35-M100
rate
f: 6.0kg[345lbs] / r: 4.0kg[230lbs]
drop
f: 1.0" / r: 0.8"
btw, this is going to be a track car, i probably wont even register it
Old Mar 19, 2009 | 02:55 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
RS-R "race" springs, Koni dampeners and Ground control caster camber platers and coilover sleeves.
Old Mar 20, 2009 | 02:25 AM
ruddyrid's Avatar
Doin' Work Son!
the rs-r race springs are a direct fit, they dont requier sleeves... do they
Old Mar 20, 2009 | 02:55 AM
certifiednut's Avatar
Mike Honcho
you could get ground control coil overs, and be able to adjust height and also pick your spring rates.
they arent that expensive, But if you are buying konis, springs and caster/camber plates, you will be spending about as much as a set of coilovers cost
Old Mar 20, 2009 | 11:36 AM
ruddyrid's Avatar
Doin' Work Son!
well the springs are going to cost about $190 w/o shipping, shock are freakin expensive, lookin at about $600 w/o shipping, and the plates $270 w/o shipping
so thats about $1080, but the ground control springs are about $150 more than the rs-r's
Old Mar 20, 2009 | 03:05 PM
Yeah, there's a reason for that...
Old Mar 24, 2009 | 03:45 AM
ruddyrid's Avatar
Doin' Work Son!
the thing is tho, that if i were 2 get ground control coilovers i would like the dampeners not to have so much stroke, which is something the koni shocks wouldnt do... i think
for a short stroke i know id have to go w/ something like cusco, stance, tein coilovers or w/e
Old Mar 24, 2009 | 07:56 AM
RussTII's Avatar
Veteran: Air Force
you could get brand new coilovers for 1080
Old Mar 25, 2009 | 11:48 AM
NoPistons!'s Avatar
Tango Down
If you're that poor, cut your springs.
Otherwise, save for a proper setup.
Old Mar 25, 2009 | 05:13 PM
Sindregutt's Avatar
Ive bought Tein RA and HA`s three times, used, from jp. Works like cream and ive paid around 500 usd for one pair. Okey, they might need some paint to look shiney but they work and are quite stiff =D
Old Mar 25, 2009 | 10:20 PM
RussTII's Avatar
Veteran: Air Force
$1000 will get you a nice set of brand new coilovers from poweredbymax
Old Mar 26, 2009 | 11:34 AM
ruddyrid's Avatar
Doin' Work Son!
ohhhhhh s***, i forgot about that company
i think ive found my answer, ill just have to wait a month or two
thanks a lot russ
Old Mar 26, 2009 | 12:13 PM
AWDRFTR's Avatar
wow we cant forget about PBM. when i first started reading the post, i did not know what you are looking for because you just said it is a track car. to best help you with what suspension setup to run, i or we would need to know what kind of racing will you be doing on the track. when i saw u were looking for a shock and spring setup. i had great experiences with Koni shocks and Eibach springs. coilovers are becoming more affordable these days, that i have had two sets of JIC FLTA2 given to me for free, i rebuild them and slap them on my car. however, for a racecar you want to keep everything as simple as possible. So what kind of racing are you doing?
Old Mar 26, 2009 | 03:24 PM
ruddyrid's Avatar
Doin' Work Son!
well i did start this thread under drifting and ill be taking this car to the track mostly
maybe a bit of street drifting[shhh] or some spirited driving here and there but im not sure if ill even register it
Old Apr 25, 2009 | 11:55 AM
ruddyrid's Avatar
Doin' Work Son!
any one has any experience with these
http://www.splparts.com/main4/parts/...on/default.htm
they're KTS coilovers running 9kg/mm and 7kg/mm spring rates.
Old Apr 25, 2009 | 04:23 PM
InsomniacFC's Avatar
Will drive for parts
Sorry to thread jack, but where would I look to find prices for the powered by max coilovers?
Old Apr 26, 2009 | 01:03 AM
DRFT_HRD's Avatar
Your Mother Is A Lizard
PBM if your broke or eGay it.
Old Apr 26, 2009 | 01:19 AM
RE TurboII's Avatar
Meow
1000 picked up or like 1100 plus shipping, they're out of stock for another few weeks so check back and give dan a call at the shop
Old Apr 26, 2009 | 03:31 AM
NoPistons!'s Avatar
Tango Down
When you say egay i automatically think of godspeed coilovers.
THANK ******* GOD I DIDN"T BUY THEM!
Old Apr 26, 2009 | 11:29 AM
ruddyrid's Avatar
Doin' Work Son!
http://www.gtfactory.jp/cms/page.php?5
u should try google sometime its fun. jk
Old Apr 26, 2009 | 11:53 AM
89fc3sgtu's Avatar
boosted fc
i would save up for coilovers you can get megan racing track series for 950 from option imports their worth it and fully udjustable
93FD510
Oct 1, 2015 02:00 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
lnlreaper
Sep 27, 2015 09:59 AM
