Microtech help with ltx12s
Old Mar 16, 2009 | 08:48 AM
rx7convertion's Avatar
rx7fever
NJ help with ltx12s
Im not getting any spark, i checked connections and everything is wired correctly, the green light is on, when I try to start the car I only see green light, please help....
Old Mar 16, 2009 | 06:12 PM
rx72c's Avatar
Top Answer: 1
This means your Crank angle sensor is malfucntioning or the wiring to it is no good.
You need to see a Flashing orange light when you are cranking.
Check your cas or cas wiring, check your plugs. thats where your problem is.
Old Mar 16, 2009 | 08:33 PM
rx7fever
I ll do that ....thanks
douwe
Microtech
Apr 9, 2009 08:13 PM
