Smoke!!!! Not Cool!
Old May 24, 2002 | 02:03 PM
jreynish's Avatar
New Project on the Way...
Smoke!!!! Not Cool!
I just got my new turbo put on my car!
It is a T04 turbo! and now when ever i drive it i see smoke comming out of my tail pipe especially after i have stepped on it! I really want to know what are the symptoms? what would make it do this?
could it be apex seals?
the engine only has like 5000km's on it!
but if it is how would i be able to test that?
but mostly anything that you think it could be let me know so i can take a look! or have it looked at! it is parked right now! so i don't damage it further!
Old May 24, 2002 | 02:04 PM
jreynish's Avatar
****correction*****
sorry i want to know what are the possible causes of this not sumptoms!!!
Old May 24, 2002 | 04:39 PM
UniqueTII's Avatar
Slow and old
What color is the smoke?
White = coolant
Blue = oil
Black = carbon or excess fuel
Old May 24, 2002 | 04:43 PM
Gefunk's Avatar
I get a lot of shitty black smoke as well...I was wondering if this could be due to running rich? How can I correct this besides a new o2 sensor which is currently awaiting to be put in?
Old May 24, 2002 | 04:57 PM
UniqueTII's Avatar
Slow and old
If you're running rich enough to smoke black all the time, I'd suspect a leaking injector or something like that.
Old May 24, 2002 | 05:10 PM
jreynish's Avatar
well the smoke is white from what i can see! but some of my freinds said that it was black!!! but i am pretty sure it was white!!!
If it was coolant how would i correct that?
I have an upgraded t04 turbo but not yet an upgraded ecu! but it was doing this before the upgrade? what would it be?
Old May 24, 2002 | 06:33 PM
jreynish's Avatar
from what i can see from the rear view and side view when i slow down it billows at the rear end and curls in over the spoiler! and it looks white!
Old May 24, 2002 | 11:23 PM
jreynish's Avatar
help!!!!
Old May 25, 2002 | 12:02 AM
Ryde _Or_Die's Avatar
Um, tear apart the engine and replace the coolant seals. Do you have any emissions stuff still on? EGT gauge? Does it smoke when you are flooring it or after you floor it and are stopped? Ever smoke when parked and idling?
Old May 25, 2002 | 12:56 PM
jreynish's Avatar
It smokes when i shift! and especially when i stop! it smokes a hell of alot! And it usually does not smoke when it is at iddling unless of course i just flored it and it is just sitting there! It does not smoke when i am just sitting there after i started it! Unless i rev it faily high like past 5500rpm! so the engine was just redone! and by mazda! but it was done with the person that did it before! wHAT DO YOU THINK MY OPTIONS ARE?
Old May 25, 2002 | 01:12 PM
dre_2ooo's Avatar
ok ok settle down.
Water is a natural product of combustion (you get something like a 8:1 ratio of water put out to combustion put it ) Most likely your secondaries are putting out much fuel (above 4000 RPMs) and that's giving you the black smoke.
There should be some water condesing and dripping from your tailpipes then. THIS IS NORMAL.
About the black smoke, it's a fuel problem. Prolly cuz you are running a big turbo with a stock ECU. You should have some BLACK soot or carbon build up on the OUTSIDE of your exhaust tips if you're running too rich too.
LOOK in your overflow coolant reservoir when the engine is warm and running, if there are SURGING BUBBLES being pumped into there, ONLY THEN do you have internal engine troubles. IF it looks stable and nice and green, DONT WORRY.
Old May 25, 2002 | 01:37 PM
jreynish's Avatar
Where do I find the overflow coolant reservoir! Ok! well that is making me a bit less worries can you PM me with the exact placement of this! cause i really want to find out what and why it is doing it!
THank You
Old May 25, 2002 | 01:52 PM
dre_2ooo's Avatar
FIND your radiator cap. Do you know where the radiator is? Look in front of your radiator. There is a small whitish tank near the VERY front of the car. A small black tube runs out of it to your radiator fill neck.
This tank is the overflow tank, there is GREEN coolant inside it. I has marking of LOW and FULL on the side. ONLY use these markings when the engine is WARM. It should read full and be tranquil at idle.
IF you see the green coolant bubbling up or it looks like there is lots of OIL in the coolant, then you're gonna need a rebuild.
IF it looks nice and steady and green, then your white smoke is just water condensation from a HOT engine to a COOLER exhaust. IT HAPPENS TO EVERY CAR (even pist0n engines).
Old May 25, 2002 | 02:00 PM
jreynish's Avatar
Ok thank you!!! and i am not that inept!!! I know where the majority of the stuff is! keep in mind i have only owned the car for about two weeks!
Thank you I will take a look at that!
ls1swap
Jun 3, 2024 03:25 PM
mulcryant
Oct 4, 2015 12:18 AM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
