need to know if its ball bearing or not!
Old Mar 6, 2009 | 03:30 PM
darkphantom's Avatar
The king of the highway!
if i post some pictures of a ball bearing turbo could you guys tell if the turbo is balbearing or not.
I just want to someone take a look to see if it is what the guy says!
thanks
Old Mar 6, 2009 | 03:43 PM
ScorpionT's Avatar
Easy to tell. You will have oil feed and return on the cartridge, and if you have an additional set of feed and return, thats for coolant.
Old Mar 6, 2009 | 04:04 PM
heres the pictures
Old Mar 6, 2009 | 04:17 PM
classicauto's Avatar
Crash Auto?Fix Auto.
No, you can have a wet center journal bearing turbo. I've got one sitting in my garage right now.
I'm no turbo guru, I can't tell from the pics.
Old Mar 6, 2009 | 04:58 PM
ScorpionT's Avatar
True, but very uncommon. Mostly on Ebay turbos.
Phantom, you have a BB turbo.
Old Mar 6, 2009 | 05:04 PM
Not uncommon at all.
Mine's an aspec, and you can order wet centers for all kinds of configurations.
Old Mar 6, 2009 | 05:22 PM
thanks scorpion.
classic auto your saying the water jets can be added to the turbo?
Old Mar 6, 2009 | 05:57 PM
TweakGames's Avatar
FD pro licensed driver
I have a water and oil t04s. Very common.
Old Mar 6, 2009 | 06:23 PM
ScorpionT's Avatar
Most journal bearing arent water cooled, at least not in the Garrett, Precision, or BW turbochargers.
Phantom, looks like you have a GT42R. Correct?
Old Mar 6, 2009 | 06:45 PM
/\ gt4202r
second picture. is that carving on the turbo legit? or did they do that
Old Mar 6, 2009 | 07:23 PM
ScorpionT's Avatar
I havent seen it before on a turbo, it may have been by a shop or distributor.
Old Mar 7, 2009 | 01:20 AM
arghx's Avatar
rotorhead
if it's not water cooled, it's definitely not ball bearing.
if it is water cooled, spin it with your fingers. If it stops almost immediately, it's journal bearing. If it seems to have more inertia and keeps spinning longer, it's ball bearing. I know that's kinda vague but if you compare the two it's pretty obvious.
ls1swap
Jun 3, 2024 03:25 PM
Vartok
16
Oct 8, 2015 04:49 PM
