Go Back   RX7Club.com > Tech and Performance > Single Turbo RX-7's
Old 03-06-09, 04:07 PM   #1
1ROTOR2NV
5th is most fun
To reroute or not to reroute ?
Well its been discussed up and down in these forums, and I have read most of it and want to come to some solid conclusions. If you have a 4inch exhaust, from what I understand the only reason to not reroute is if you love the loud sound. I read alot about the re-entry angle, position in relation to the manifold, pipe size and how it affects back pressure but from what I understand with a 4inch or larger you can reroute with basically no drawbacks to performance, is this correct. Also just to confirm if I am running a gt42R and I set the boost for 18 psi, this would mean that in a perfect world, so long as I am boosting under 18, the wastegate is closed and thus not making any noise, its only at full boost with WOT that the gate would open and cause onlookers to require ear surgery, does that about sum it up.
I know its dangerous asking general questions like this because someone is gonna wanna micro anylize the 6 hp loss at 6317rpm, but in a nut shell is this all sound logic. Also for the guys running a little higher boost that do not have a reroute, is the volume that bad, or is it tolerable, again I know general question, for what its worth I like it a little loud.
1ROTOR2NV is offline   Reply With Quote
Old 03-06-09, 04:09 PM   #2
afgmoto1978
It will attract Cops non rerouted, hehe.
damn, looks like you're off to the moon with all that foil !
That is the most high tech FD engine bay I have seen. Almost looks like you stuffed a satellite under your hood. lol
your engine bay is so crazy with the gold, it's like strait out of star wars.
Old 03-06-09, 04:16 PM   #3
classicauto
Crash Auto?Fix Auto.
classicauto's Avatar
Just an open wastegate with a dump tube is LOUD. Make no mistake about it.
Also, it'll open any time you let off the gas. Not just WOT at peak boost to bleed off pressure.
Pluses:
You know your wastegate is working
I've run wide open, and open with a muffler setup. I'd like to try some more muffler setups, but this year I'll be re-routing it because I haven't tried that (on this car) yet.
The only way to apex a corner is with apex seals under the hood!!
"These four wheels feel like home to me.......they breathe" - Flatliners, This Respirator
classicauto is offline   Reply With Quote
Old 03-06-09, 06:26 PM   #4
1ROTOR2NV
5th is most fun
Thanks for the insight, looks like I will be re routing, anyone have any pics of their reroute, with an A SPEC manifold, v-band if possible, thanks.
Old 03-07-09, 01:33 AM   #5
AMRX7
You should be able to find pic of what you want on this thread.
http://www.rx7club.com/showthread.php?t=814635
I just got this setup from A-spec. Seeing how well the reroute was done, I can't see it hurting performance much if at all.
-Andy
AMRX7 is offline   Reply With Quote
Old 03-07-09, 02:14 AM   #6
Dudemaaanownsanrx7
Brent Vogl -Thousandaire-
Dudemaaanownsanrx7's Avatar
Trader Score: (18)
Send a message via AIM to Dudemaaanownsanrx7 Send a message via Yahoo to Dudemaaanownsanrx7
Mine is open, i don't think the noise is that bad. And mine doesn't open when i let off the gas, only about 2 psi before my target boost does it open.
500+ rwhp thanks to:
Fast reacting open element IAT, Pre turbo water injection, master power t70 @ 23psi, streetport, pfc, twinpower, greddy plugs, ebay intercooler, 3" exhaust, cold air intake,TII LSD, solid mounts, braces, wideband, datalogit, my tune, dual FD fuel pumps, profec b, 550/1680
Dudemaaanownsanrx7 is offline   Reply With Quote
Old 03-08-09, 02:30 PM   #7
1ROTOR2NV
5th is most fun
So why is it thtat everyone else says its crazy loud, just the 4 inch system itself or the dump to atmosphere is loud???
Old 03-08-09, 03:23 PM   #8
Halfbridge
Brap Brap Brap
Halfbridge's Avatar
Send a message via AIM to Halfbridge
Yes
Halfbridge is offline   Reply With Quote
Old 03-08-09, 06:10 PM   #9
Zero R
Just in time to die
Zero R's Avatar
WG will always crack open before target boost level is reached. I've had cars here dump to atmosphere that weren't that noticeable. I've had others that were horrible sounding. I think a lot has to do with how it's dumped ie length of pipe, pipe diameter, exit etc.
As example I had one car here running our long runner with almost no dump at all and you couldn't even tell when the gate opened.
A-spec turbo kits, best warranty, track proven.
<--- click it
Your #1 source for GT series turbos for your Rotary.
In house Dynojet services (1500hp with load control).
Zero R is offline   Reply With Quote
Old 03-08-09, 06:25 PM   #10
arghx
fast car=no money
arghx's Avatar
On my old setup I ran the FC HKS log manifold with a standard (40mm) gate. I had it bolted right to the manifold flange. There wasn't much room to route a dump pipe so I just had it open. That thing was earsplitting.
-- 1988 Rx-7 Turbo II, T04R
-- 1997 Infiniti Q45 Touring
-- Sold: 1988 Rx-7 GTU, 172rwhp all motor
-- RIP: 1989 Supra
arghx is offline   Reply With Quote
Old 03-08-09, 06:47 PM   #11
Dudemaaanownsanrx7
Trader Score: (18)
Mine doesn't have a dump tube just the gate open. It's loud under boost but not that bad. It doesn't hurt your ears or anything. I like how it sounds. Mostly quiet until i'm racing then the gate opens and i fly by.
Old 03-09-09, 05:04 PM   #12
afgmoto1978
Dumped to atmosphere video
http://videos.streetfire.net/video/P...n-a_188521.htm
Old 03-11-09, 08:18 PM   #13
CowsniperRX7
Rear Admiral
CowsniperRX7's Avatar
Send a message via AIM to CowsniperRX7 Send a message via MSN to CowsniperRX7
My open wastegate makes my ears bleed. If I'm messing around with someone on the highway and they are on my passengers side with the windows down...they almost crash.
But yeah I'm getting mine re-routed into my exhaust. F-that noise.
--Chris
--Silver 93 Touring 5 speed
"It's amazing what we've learned...its not that we've wanted to learn it...but we've learned it"
CowsniperRX7 is offline   Reply With Quote
AFM reroute(S4) villin 2nd Generation Specific (1986-1992) 4 02-15-08 03:24 PM
Anybody know how to reroute the oil injection to burn oil from a different source? TriangleMan 2nd Generation Specific (1986-1992) 5 04-15-03 01:02 AM
