Only 6 pounds of Boost at WOT??
Old May 23, 2002 | 01:03 AM
BlackRx7's Avatar
Daily Domestic Killer
Yeah I just installed my autometer boost gauge and every time it just stops at 6 psi, it hits it at like 4k rpms, and stays there all the way to 7k rpms, I do have a precat, but no main cat and straight through mufflers.
could my precat be cloged?
Old May 23, 2002 | 01:11 AM
FC Drifter's Avatar
Damaged Little F*cker
yeah chuck that pre-cat. its a definate boost restriction. im not sure if thats the only reason, but its definatley a big one. make sure your gauge is reading properly. check the vac line and make sure its not pinched anywhere, has a good pressure source, etc.
Old May 23, 2002 | 01:23 AM
Felix Wankel's Avatar
Super Newbie
The capillary tube it comes with is really shitty.
peejay's Avatar
Old [Sch|F]ool
That's spec boost, you shouldn't be going over that without a boost controller
Boost going up because you de-restrict the exhaust only means your wastegate isn't big enough
Shainiac
Jul 17, 2019 02:20 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
Bauer778
Nov 4, 2015 04:42 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
