Can I change only motor from FD to FC?
Old May 23, 2002 | 12:57 AM
kylekyle's Avatar
Question Can I change only motor from FD to FC?
If I had ONLY MOTOR from FD and would like replace it instead FC motor, what everithing I need from FD?
FD Intake???
FD Clutch and transmition?
FD Senzors, cabels and ECU?
...or can I use everithing from FC?
How size have FD motor, same as FC???
Thanks, Kyle.
Old May 23, 2002 | 02:13 PM
vaughnc's Avatar
knowledge junkie
kylekyle,
Most of the series VI turbo IIs (ie FD motor) use an aftermarket ECU/computer. I'm not sure on the drivetrain pieces, but I'd imagine there would be some work bolting the engine to the TII transmission. I'd do a search in the 2nd gen section for "series VI" or "FD motor" or "3rd gen swap".
Old May 23, 2002 | 04:05 PM
RacerXtreme7's Avatar
NASA geek
What the heck are you asking???? You want to stick a FD engine in a FC. Its going to be difficult, you'll need the ENTIRE intake from FD, and the ENTIRE wiring harness and CPU unless you go aftermarket. Your gonna have to MAKE motor mounts. The FC and FD tranny bolt patterns are the same, in fact the 89-91 trannies are the basically the same as in 93-99 except the rear tail section and some other minor things.
The1Sun
Mar 18, 2018 11:08 PM
Skeese
65
Mar 28, 2017 03:30 PM
incubuseva
14
Sep 3, 2015 12:37 PM
85TIIDEVIL
Aug 25, 2015 12:09 AM
PhillyFC
Aug 21, 2015 06:36 PM
