View Poll Results: To Wastegate or NOT??
Stick with the INTERNAL and port it
50.00%
Go EXTERNAL
50.00%
Screw the wastegate.. just use a Pop-off valve
0%
What's a wastegate?
0%
Voters: 2. You may not vote on this poll
Seized Wastegate
Old Feb 12, 2009 | 11:12 AM
Bearzah's Avatar
Me Wantee Da' Boostee
Seized Wastegate
People, I need help.
I have a 1st gen 12A with a CarTech drawthrough setup
https://www.rx7club.com/1st-generation-specific-1979-1985-18/12a-cartech-drawthrough-help-814461/
RHB6 Turbo
My wastegate swing valve is seizing and I was looking for advise. I was able to WD40 it enough to get it to work FAIRLY freely, but, after running it for about a week it appears to be happening again.
Any suggestions on how to repair/replace this?
Attached Thumbnails Seized Wastegate-img_0010.jpg   Seized Wastegate-img_0009.jpg
Old Feb 13, 2009 | 11:34 PM
Bearzah's Avatar
Problem Solved
Wastegate problem fixed. The flapper is welded to the shaft which was making a fix more complicated.
I ended up taking the wastegate swing swing valve housing to Bell Turbo in Corvallis, OR. They cleaned it torched it to burn out any rust and let it soak overnight in acid to get rid of any corrosion. This morning (after soaking in a neutralizer) they bead-blasted the gate, re-torched it to burn-out any bead media which might have worked its way into the shaft than oiled it.... Flops around freely now... WOOT!!!
They also trued up my mounting surfaces while they were at it.
I am very pleased with their work.
Without an the exhaust leaking past the valve, the car sounds SOOO much better and you can hear the turbo whine a bit when it spools with a load WOOSH when the wastegate opens
I adjusted the wastegate linkage to let-off at 10psi and tweaked the carb again to run at 11.5-11.8:1 at WOT.
Attached Thumbnails Seized Wastegate-img_0017.jpg   Seized Wastegate-img_0018.jpg   Seized Wastegate-img_0019.jpg
Old Feb 15, 2009 | 04:53 AM
arghx's Avatar
rotorhead
what turbo is that by the way?
Old Feb 15, 2009 | 04:19 PM
Bearzah's Avatar
sure.. The link in my 1st post directs you to my thread about the setup
Old Feb 15, 2009 | 04:53 PM
rx72c's Avatar
Top Answer: 1
Can you stick a external wastegate anywere?
Save you the headache.
Old Feb 15, 2009 | 05:45 PM
arghx's Avatar
rotorhead
RHB6 is the Probe/Mx-6 turbo?
Old Feb 15, 2009 | 07:58 PM
Bearzah's Avatar
u could install an external on it, but, this one is fixed and working great now.
The RHB6 is similar to a T3
Old Mar 23, 2009 | 11:28 AM
Bearzah's Avatar
Thanks for the help all.
If you have any more comments.. please see my main thread at:
https://www.rx7club.com/showthread.php?t=814461
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Robrods64
Oct 2, 2015 07:56 PM
