Transmission Mounts
Old May 22, 2002 | 01:09 PM
pd_day's Avatar
Spoolin'
Transmission Mounts
How often do the tranny mounts go bad?
what are the symtoms of bad tranny mounts?
I am going to be installing a new clutch.....good idea to change them too?
Thanks
Old May 22, 2002 | 01:18 PM
Scott 89t2's Avatar
SOLD THE RX-7!
the mazda comp ones are only $10 each. why not!!
Old May 22, 2002 | 01:47 PM
pd_day's Avatar
Spoolin'
Did you put those on your car yet?
How long was the shipping to Canada?
Old May 22, 2002 | 02:28 PM
There are 2 types of tranny mounts... A
A: the big crossmember( which has a rubber bushing PRESSED into it... You can't replace the bushing, have to buy the whole new part..) 70 bucks at mazdatrix I think..
B: Then there are (2) "Y-block mounts" up above that are like 10 bucks each...
shipping probably about 4-5 business days, unless you pay more for quicker shipping.. that's to Omaha NE at least.. not sure about toronto
Old May 22, 2002 | 03:42 PM
Scott 89t2's Avatar
SOLD THE RX-7!
going on tomorrow, with the mazda comp front diff mount as well. less then a week I think.
Old May 22, 2002 | 03:56 PM
pd_day's Avatar
Spoolin'
Hey Scott, do you have the part numbers for the tranny and diff mounts?
Thanks a million
Old May 22, 2002 | 08:37 PM
Scott 89t2's Avatar
SOLD THE RX-7!
fcy1-28-680 front diff $63.90
fby1-39-340 tranny. $11.30 each. need 2.
Old May 23, 2002 | 08:39 AM
pd_day's Avatar
Spoolin'
thanks man
Old May 23, 2002 | 11:22 AM
Scott 89t2's Avatar
SOLD THE RX-7!
dam it's nice to have a lift and air tools. we changed the front diff mount at my mech. shop in 1 hour. pretty easy. I've heard so many nightmares about that one
Old May 23, 2002 | 11:27 AM
are you not replacing the crossmember mount? That is the one that usually goes bad.. The others are just Rubber blocks basically...
The crossmember has a rubber bushing in the middle that can acually TEAR apart, and once that happens you will notice some vibration at idle... Only way to replace the rubber bushing is to replace the whole cross member... Check the crossmember when you replace the Yblock mounts..
