Best 60 ft times with Nitto 555R's?
Old May 21, 2002 | 11:25 PM
VELCRO SHOES's Avatar
Red face Best 60 ft times with Nitto 555R's?
With my new Nitto 555R's can I hopefully expect something below a 1.8?Maybe a 1.7-6?????
Old May 21, 2002 | 11:35 PM
relvinnian's Avatar
Depends heavily on mods and suspension setup. If you launch with alot of torque built up, and the suspension is setup well, you could definately see 1.7 60'.
Nitto 555Rs are not the best "all-out" drag radial. They make for good all around performance, and will launch better than a street tire. You've got a T51 am I correct? You are going to want to launch the car on boost in order to get a decent 60'
Otherwise, I would prefer Geforce T/A, or ET Streets
Old May 21, 2002 | 11:47 PM
Yah,I have the T51R KAI.I bought a line lock hoping that will help me produce boost off the line but we'll see if I can get that thing to work......
I know the guys running around with the LS1's etc etc are pulling off 1.6's etc etc off 555r's but I just didnt know about what luck anyone with RX7's have had with them?
Old May 22, 2002 | 12:03 AM
relvinnian's Avatar
Line lock is for burnouts. Locks the front brakes so the back can spin un-hindered.
You need a secondary rev limiter (2-step). Whatever EMS you are using should have it built in.
-Brian
Old May 22, 2002 | 12:40 AM
Yeah thats what I meant heh
How does this secondary rev limiter work?I have the power fc
Old May 22, 2002 | 01:38 AM
relvinnian's Avatar
Read your manual.
With MSDs you just wire it off of the clutch plunger/circuit. I would assume it would be that way for any 2-step.
Once you figure out how to wire it, just take it to the track and test different RPM points to launch at, while building boost.
Edit: Come to think of it, you probably don't have to wire anything. That circuit is already part of your wiring harness. You'll just need to find the setting on the PFC for secondary rev-limiter
Old May 22, 2002 | 11:17 AM
I read it but it still didnt explain exactly how a secondary rev limiter will create boost,just curious is all?
Old May 23, 2002 | 01:57 AM
relvinnian's Avatar
https://www.rx7club.com/forum/showth...threadid=79608
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Microtech
30
Apr 23, 2016 06:37 PM
incubuseva
14
Sep 3, 2015 12:37 PM
