need help please car has no power
Old Feb 1, 2009 | 05:46 PM
mazdarx7fcman's Avatar
mazdarx7fcman
car runs fine drove it 2days ago before i park it has a cooling leak also from the under the intake manifold dont no if it has a cooling line help with that to please cause i changed a cooling line behind the alternater so after i took off the intercooler and alternater put every thing back then no power in the hole car noting works tnx.
Old Feb 2, 2009 | 05:37 AM
Go48's Avatar
It would be helpful if you let people know what model car you are referring to.
Do you mean no "electrical" power? If so, check the wiring associated with the alternator since you messed with that. Otherwise, provide more specific information on the problem in a way that people here can understand. You know, sentences, periods and the such. We need the "hole" story.
For the coolant leak, there is a coolant line that runs from the water pump through the BAC valve to the rear of the engine under the upper intake manifold. That may be the source of your leak. In which case you will likely have to remove the manifold in order to replace the hose.
BTW, welcome to the forum. Be aware that most, if not all, problems that people experience with these cars have been written about many times over. So, it's best to search before posting to find answers to questions you may have in the future. Also, get a copy of the factory service manual at one of the links in the respective FAQ for the model/generation of your car.
Old Feb 2, 2009 | 06:15 PM
mazdarx7fcman
tnx for the info also my car is a 88 tII.
Old Feb 2, 2009 | 07:04 PM
mazdarx7fcman
he would u no how to take off the intake manifold tnx.
Old Feb 3, 2009 | 12:12 AM
MMoore4545's Avatar
remove the soft hose between the airbox/manifold.
unbolt the hard plastic elbow, remove it.
pull off and cap the Coolant return lines (carefully)
slide off the throttle cable from the cam
pull off the vacuum lines
remove the four bolts holding it in
and unplug the TPS
that's about it. Reverse order to put it on,
make sure you don't create a bubble in your coolant system,
it's also pretty normal to find just a little oil between the throttle body and lower.
if you're looking for EVERYTHING (throttle body, upper intake, lower intake) removed, look it up in the FSM
Old Feb 3, 2009 | 06:00 AM
mazdarx7fcman
tnx alot.
Old Feb 12, 2009 | 10:52 AM
mazdarx7fcman
Originally Posted by mazdarx7fcman
tnx alot.
i have a t2 so how can i take off the top intake... tnx
ChrisRX8PR
Aug 21, 2015 01:56 PM
gtcd
30
Aug 19, 2015 02:44 AM
cam_7779
Aug 18, 2015 07:48 AM
sYnth.
Aug 17, 2015 07:28 PM
