Haltech Need help
Old May 22, 2002 | 11:40 AM
tims's Avatar
I would make sure all wiring is correct and all connections are soldered, no crimp connectors. The only way to check the signal to the igniter is with an oscillascope(spelling?). also may have to make some changes to the map if the black smoke continues(very rich condition). plugs on the leading side could already be fouled and this is why it looks like it is running on the trailing only. check the plugs and wiring and make some changes to the map. have a couple sets of new plugs ready while doing the tuning, you will need them.
