RX-7 Store Questions for the RX-7 Store about parts, orders and Group Buys.
Now Stocking Spek Gauges
Old Jan 20, 2009 | 04:03 PM
Jason's Avatar
The one
Spek makes a high quality gauge with the controller built right in. Checkout their info here http://propartsllc.com/spekGaugeCont...hp?subCatID=20
Im also adding them to the store
http://www.rx7store.net/category_s/500.htm
Some of the key features:
* 7 color background setting with day and night background and pointer dimmer settings
* Lighted High and Low programmable warning settings, background will flash Red if high or low limits are hit.
* Plug and Play wire harness for easy installation.
* 2 Outputs to drive a 2 amp load when set High and Low limits are activated. If a fan option is need Part
* Mounts in standard ProParts Pod or can be used with universal steering column bracket #81102
* PEAK playback and flashing ON/OFF warning background is limits are hit. (This feature can be disabled)
* Brushless stepper motor with full sweep 280 degree pointer
* Patented lighting delivers on e of the largest and biggest displays ever assembled on a 2 1/16 inch gauge
* Easy to read Analog lighted pointer
sYnth.
Aug 19, 2015 06:27 PM
