Shift light on at WOT?
Old May 20, 2002 | 11:05 PM
brap brap
Question Shift light on at WOT?
the Shift light shouldn't come on should it? I mean, normal accelerating, sure...but when WOT down to 7k or so, it shouldn't come on.. Anyone know why?
Brian Smith and my boyfriend thinks it's the TPS... anyone know?
Old May 20, 2002 | 11:10 PM
brap brap
I'm pretty sure it shouldn't come on at WOT. When shifting normal, yeah.. but at WOT?
Old May 20, 2002 | 11:18 PM
brap brap
it normally doesnt do that, but lately it has.
Same goes with the buzzer. Sometimes it'll go off at 6k-6500 .. or at 7k-7500... and redline is at 7k.
Old May 20, 2002 | 11:32 PM
knight1976's Avatar
LOL yea if that doesnt work put in a luder stereo.
Old May 20, 2002 | 11:35 PM
brap brap
Old May 21, 2002 | 12:12 AM
FC Drifter's Avatar
Damaged Little F*cker
the shift lights in FCs are always lighting up when they shouldnt. at least both T2s ive owned have done that. what i did was take the instument cluster out and remove the light bulb. that fixed the annoying problem. i know when to shift anyway. i dont know about the buzzer thing though. mine never do that.
Old May 21, 2002 | 04:02 AM
TonyTurboII's Avatar
Glock Lover
Follow the light and you will get great gas milage. Why do you think its there?
Old May 21, 2002 | 07:34 AM
jacob's Avatar
i don't think my car has a shift light.....i've never seen it light up, where's it located? the previous owner did have a new engine put in, maybe they didn't hook up all the wires.
Old May 21, 2002 | 09:32 AM
brap brap
Yeah, I know that Tony...
I just don't think it should stay on a WOT, and why? It doesn't bother me a whole lot.. I just want to know if something's wrong, or what?
Other than that, it's Ok..
Old May 21, 2002 | 09:38 AM
it should stay on after the set RPM... if the light is set to come on at 2700 RPM, Then it's going to turn on at 2700 and stay on until you shift under it... or at least on my car it should it's not as advanced to tell if you are WOT or not and the buzzer... when I'm in first gear flooring it, the buzzer usually pops on at 6500 (7k redline) and by the time it kicks into my head, I'm at redline.... assuming they set it to 6500 just to warn you , you are nearing redline and not to go over it
Old May 21, 2002 | 01:51 PM
brap brap
Yeah, I just wondered if that was suppose to happen or not. Kinda werid that it would stay on at WOT though.
Another question... is it harmful to go past redline (7k) down to 8k on a stock engine? A few I talked to said nah.. it won't damage a rotary... but I dunno.. still kind a leary on that...
Old May 21, 2002 | 02:41 PM
Icemark's Avatar
The shift light will come on at WOT, it will come one anytime that a higher gear will give you a better vacuum reading (except in 5th).
rx7shirley
Sep 2, 2015 02:11 PM
