Power FC Updated Half Bridge PFC Maps
Old Jan 7, 2009 | 10:52 PM
BDC's Avatar
BDC
BDC Motorsports
Hey guys, I updated the few half-bridge maps, zipped 'em up, and put 'em up on the website. They're new sets of IGL curves for the half-bridge setups. No changes to any of the other maps.
http://bdc.cyberosity.com/v/Technica...d/PowerFCMaps/
File is BaseMaps_Jan 07 2009.
B
Old Jan 10, 2009 | 07:01 PM
arghx's Avatar
rotorhead
did you just add a little timing under low load?
another question. I am looking at your 550/1680 HBP map. You have the idle set to like 1400. Since the PFC likes to ignore the timing map at idle, what actual timing values are you logging with this setup at idle? and how much bypass air (through the air adjust screw etc) does it need to idle stably?
and another tangentially related question: since rotary motors with lots of overlap (bridge port etc) seem to need lots of timing under low load and much less timing under high load, does that principle apply to turbo piston engines with aggressive cams? i may be helping my friend tune his Vr-4 with big cams
Old Jan 11, 2009 | 11:47 AM
BDC's Avatar
BDC
BDC Motorsports
I actually removed some in lower RPM, lower loads. I had it kicked a bit too far forward.
At idle I think the PFC is still trying to idle it at 5*BTDC or something to that effect. The HBP engine seems to like about 32-33*BTDC at idle at 1200-1400rpm.
I would say the same principle applies, yes.
B
Old Jan 22, 2009 | 10:02 AM
quick_spoolin's Avatar
I'm Single..Turbo that is
I dont know if you cought this error but on you hfbp 850/1680 map you have 850 and 1500cc injectors selected in your settings.
Old Jan 22, 2009 | 10:38 PM
BDC's Avatar
BDC
BDC Motorsports
Just a text field. Not any bother but I appreciate lettin' me know.
B
24seven_dada
20
Nov 10, 2018 12:03 PM
dillrx7
Sep 7, 2015 09:38 AM
befarrer
Sep 4, 2015 08:26 PM
rx7shirley
Sep 2, 2015 02:11 PM
