Sponsored by: CARiD
air/fuel ratio gauge
Old Jan 4, 2009 | 09:03 AM
tatu2183's Avatar
i got an air/fuel ratio gauge from jdmsports and it doesnt come with a wideband o2 sensor and they told me to hook it up to the ecu...i did that and when the car is on the gauge is buried....any help with that would be good....
Old Jan 6, 2009 | 10:30 PM
farberio's Avatar
NASA-MW ST4
You will need to post what wideband you got for any help.
Old Jan 7, 2009 | 12:45 AM
2slow4stock's Avatar
The waiting game......
What kind of wideband? Most widebands these days take the bosch lsu wideband o2 sensor.
Old Jan 7, 2009 | 09:18 AM
Tom93R1's Avatar
gross polluter
Sounds like you just have a narrow band gauge that reads the stock O2 sensor. Pretty much useless especially on a rotary as it will always read rich. You need what's called a "wide band" oxygen sensor if you want to get any readings that are meaningful.
Old Jan 7, 2009 | 04:54 PM
tatu2183's Avatar
ok...i never put in a different o2 sensor....thats prolly it...thanx
Old Jan 10, 2009 | 04:06 PM
tatu2183's Avatar
finally got ahold of the company that i got the gauge from...they said a stock o2 sensor will and i told them that when i turn on the car the gauge is buried on the rich side...they told me to check the volts or ur just runnin rich....talked to rx7.com and said standard voltage on a o2 sensor should be 0 to 1 volt...normally around
.08 volts....but i thought u would need a wideband o2 sensor?
Old Jan 10, 2009 | 05:48 PM
marshall13B's Avatar
Apprentice Tech.
where would one get a wideband o2 sensor? and any idea on prices?
Old Jan 10, 2009 | 11:31 PM
Tom93R1's Avatar
gross polluter
Stock O2 sensors (a narrow band) pretty much only tells you whether you are richer or leaner than stoich which is 14.7 AFR's. Leaner and it reads really low volts like .08 sounds reasonable. Richer than that it will go high to almost 1 volt and read rich. Stoich is supposed to be an ideal AFR for piston engines for emissions purposes which is much leaner than a rotary runs. So you will almost always read rich. Narrow band gauges on rotary engines are not so useful.
Look for something like the Innovate kit
http://www.innovatemotorsports.com/products/kits.php
or the NGK
http://www.ngksparkplugs.com//produc...000&country=US
There are lots of threads regarding wide band sensors and controllers if you do a search.
Old Jan 11, 2009 | 07:31 AM
tatu2183's Avatar
u can buy them from rx7.com....price range is from $70 to $300 depending what type of o2 sensor
Old Jan 11, 2009 | 07:35 AM
tatu2183's Avatar
so...do u think i need to go with a wideband...the 70 dollar wide band sensor that rx7.com has is a bosch o2 sensor(i think)...think that will work for me?
Old Jan 11, 2009 | 08:55 AM
DAVIDP's Avatar
You will also need a controller for the wideband sensor the sensor alone won't work with your gage. If you go with Innovate Motorsports the LC-1 Lamda Cable P/N:3769 should work with your gage it's programable and comes with the sensor $199. The sensor should be mounted farther down the exhaust stream though it can overheat. The stock position can be too hot.
Old Jan 11, 2009 | 12:15 PM
NJGreenBudd's Avatar
rx-for-my-7
Ok. Hold on.
The stock O2 sensor isn't useful for monitoring your A/F ratios and should have nothing to do with a proper Air Fuel Ratio gauge.
You are going to leave the stock O2 sensor alone and install a completely separate Wideband O2 Monitor kit like the NGK A/Fx.
Old Jan 13, 2009 | 04:46 PM
tatu2183's Avatar
yea...jdmsports company are pretty worthless...dont buy nutn from them...
20B Forum
21
Mar 22, 2022 01:00 PM
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
