Where are the fuel lines located??
Old May 19, 2002 | 08:52 AM
rxspd's Avatar
where are the fuel lines located?? Are they the ones just to the left of the oil filter?? My car wont start, it's getting plenty of fire, but i dont think it's getting gas, i need to find out if it's the pump, or the injectors.
Old May 19, 2002 | 09:00 AM
Aaron Cake's Avatar
Engine, Not Motor
Most likely it's the pump. There is a check connector in the on the passenger side of the engine bay near the airbox. It is a yeallow two pin connector. Short the two pins, then turn the key to "on". You should be able to go to the back of the car and hear the pump. If you do not, then the pump is probably dead. Verify by measuring 12V at the pump connector. Replace the pump.
There are two fuel lines located beside the oil filter. They come up from under the car. The feed line is closest to the front of the car, the return line is closest to the firewall.
Old May 19, 2002 | 09:46 AM
rxspd's Avatar
ok, im getting plenty of fire, and there is plenty of gas coming through the lines, but the car wont start. So the only thing i can think of are the injectors, any ideas??
Old May 19, 2002 | 12:18 PM
darkwaveboi's Avatar
Need donor car in Fairfax
compression..?
Frisky Arab
13
Aug 18, 2015 05:30 PM
