No Boost from my T2
Old May 19, 2002 | 12:27 AM
RevinRx7's Avatar
Concerned Citizen
No Boost from my T2
Ok just bought a TII and idk why there is no boost. The car is thought to have Low compression, would this be a factor? It also has a shitty connection to the coolant sensor in the throttle body could that be it? IDK what it is i need help!!
Old May 19, 2002 | 05:57 AM
NZConvertible's Avatar
I'm a boost creep...
Re: No Boost from my T2
Neither do we! You need to tell us why you think there's no boost. Factory gauge? Aftermarket gauge? Performance?
Maybe, but you need to verify it by having it tested properly.
Not likely, but fix it anyway because it could cause other problems. And that's the air temp sensor on the TB inlet. The coolant temp sensor is on the back of the water pump housing.
Old May 20, 2002 | 12:17 PM
vaughnc's Avatar
knowledge junkie
RevinRx7,
It might be quicker & cheaper overall if your local rotary / rx-7 specialist mechanic takes a peak at her.
-- vaughnc
Old May 20, 2002 | 06:17 PM
RevinRx7's Avatar
Concerned Citizen
Thanks for the advice vaughn, but there is no such thing as a "local" rotary specialist here in wisconsin. So i am stuck with it myself.
Old May 21, 2002 | 11:37 AM
vaughnc's Avatar
knowledge junkie
download the shop manual and get your hands dirty
Old May 21, 2002 | 06:55 PM
RevinRx7's Avatar
Concerned Citizen
Oh i have the manual and am totally willing to get my hands dirty, its just that the turbo rotary is new to me and i am a little intimdated i must say. But yeah once i title the car and everything i will be driving it to work where i can work on it there and stuff. as for now i just don't have the time.
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
