External wastegate help
Old Dec 25, 2008 | 07:05 PM
SEDUCE's Avatar
Hi guys i own a fc with 13b turbo in it and i am currently fitting a t66 or gt35r on to it but i want to know what size wastegate i should use. the guy i brought the turbo off is selling me a 50mm one but i want to know what is the difference if i used say a 40mm or 44mm?
What is best to run and can you please tell me what the differences are in using the different sizes please, thanks a lot
Brad
Old Dec 26, 2008 | 12:34 AM
SEDUCE's Avatar
anybody know?
Old Dec 26, 2008 | 01:42 AM
calicrewchief's Avatar
RotorHead
I've read that with lower boost levels you want to use a larger wastegate. Since there will be more exhaust flow through thr wastegate your less likely to see boost spike.
Old Dec 26, 2008 | 11:06 AM
Zero R's Avatar
Just in time to die
44mm or larger would be the way to go. Keep in mind just because it is a larger mm WG doesn't mean it will flow better. TiAL's 44m gate flows better than their 46mm gate. I would look at TiAL 44mm or the synchronic gates if possible.
Old Dec 27, 2008 | 12:08 AM
arghx's Avatar
rotorhead
^ how or why is it that the 44 flows better than the 46?
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
