N/A 13b power capabilities?
high compression rotors and porting is a requisite.
BTW, you should post this under "Naturally Aspirated Performance Forum" under the Rotary Car performance section
for a so-called "streetable" setup, expect 160-180rwhp or so depending how you build it. you can get enough power for actual track racing but for drag racing it's not going to fast easily without more extreme setups.
A well prepared SCCA legal E prod motor will make between 230-260 hp at the flywhell, depending on intake( Carb vs. FI ) and exhaust. This would be a large street port, intake and exhaust port matched etc. This translates to 200-230 hp at the rear wheels.
Trending Topics
That is impressive but don't discount a Renesis. It's still a far superior engine. A pre-'09 motor when tuned right can hit right at 260 fwhp (230 rwhp) and at least one '09 stock Renesis has been tuned to 280 fwhp. It's better than most realize. The unfortunate thing is that the RX-8 is way too heavy and that it's tuned like crap in that car. Then you get more of the tuners who can't seem to get much better for some strange reason. You get someone that knows what they are doing and that motor is a dream come true.
The number of those 'experts' for the renesis from the looks of it are going to surpass the 'experts' for the REW/FD's!
The best N/A dyno I've ever seen on a renny is 220whp, from teamrx8.
Do you have a link to those 280whp dynos? I'd be elated to see that this engine can get there, my broke *** renny puts down 152whp no one can figure out what the hell is wrong with it...new plugs, coils, etc...good compression....20k miles...
Just because someone hasn't posted a dyno on some forum somewhere doesn't mean it hasn't been done. Forums are little pissing contests anyways. Team doesn't have the most power even though he thinks he does. He's not bad though.
Chris take all the shots at me you want. I've got nothing to prove to anyone anywhere and I could care less what anyone thinks including you.
for a street car, where you might need things like mufflers, and converters (i live in CA, every rx7 ive ever owned has legally passed smog), the renesis is a great choice...
apparently the stock Renesis apex seals don't take kindly to peripheral exhaust ports, so you'd need to have the apexes modified to use older apex seals. side seals will need to be clearanced for use with the older engines.
if by "eletro shaft" you mean eccentric shaft, then no.
also i believe the corner and side seals are in a different place on the renisis and they could fall into the port on a small street port if it isn't done right.
where am i again?
Wicked93gs
Aug 23, 2015 10:14 AM
ncds_fc
Aug 15, 2015 10:06 AM
