Microtech Injector Question
Old Dec 17, 2008 | 08:19 AM
DelSlow's Avatar
Hot Dicken's Cider
Injector Question
I have had this question I need answering for a while now and I really need to get the issue resolved before I can continue.
I have an LT-8s and want to run 2x1300cc primary injectors and 4x1600cc batch-fired secondary injectors. These are all low impedance injectors. The manual says the Microtech can run 8 high impedance batch-fired injectors.
Can I mix impedances between primary and secondary injectors? I was thinking I could run the primaries without resistors and use resistors with all of the secondary injectors. Do I need to run resistors at all? I really need an experienced opinion on this, I don't want to burn up an injector driver or something and get raped by Microtech on repair costs.
I emailed Microtech once before, but did not recieve a response.
Thanks
Old Dec 17, 2008 | 09:44 AM
to_slow's Avatar
Yes running 2 injectors per channel is fine,provided they aren't super low impedence
You can safely go down to 1.25 ohms per driver (you could run 2x 2.5ohm injectors)
Any lower than that & you will have problems.
Hope that helps
Thanks
Old Dec 17, 2008 | 04:31 PM
rx72c's Avatar
Top Answer: 1
Youll be fine.
Old Dec 17, 2008 | 05:17 PM
DelSlow's Avatar
Hot Dicken's Cider
Excellent, no resistors it is. Thanks for the responses.
Old Mar 28, 2011 | 06:18 PM
Trots*88TII-AE*'s Avatar
4th string e-armchair QB
I know, old thread. But, is it possible to run 4 low-impedence injectors per driver in any way? ECU is an LT-10s, Injectors are Bosch EV1 1600 white-tops, 4.5 Ohms resistance. I know it's 4 amps per driver on the Microtechs, but I'm useless when it comes to Ohm's law.
Skeese
65
Mar 28, 2017 03:30 PM
morataya
Microtech
Aug 16, 2015 09:39 AM
